Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
I am having a problem hooking up my Sony DVD player to my new Sony HD TV. The Inputs are labeled Y/Pb/Pr. My Monster cables are marked Y/CB/CR. Pleas advise
  • nardo1 Sep 24, 2008
    Thanks for the info. I finally figured it out after continuously switching cable. Then I realized I had to connect audio cables as well. Thanks again, I'm up an running.
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Posted on Sep 22, 2008
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Regards,
BElectric
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
Dvd player only plays in b&w, and connectors dont seem to match up with tv
Go into the player's setup menu and make sure it's set for the kind of connection you're actually using (component, S-video, composite). Also make sure the connections are pushed "all-the-way-in" Lose connections can cause B&W picture.
Sep 09, 2007 | Televison & Video
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
Problem adding dvd to digital converter box/tv mix
tengo un control remoto universal sony RM-v210
por favor si save como progamarlo escribeme a rical2903@hotmail.com
gracias anticipada.....
Aug 02, 2009 | GPX D1816 DVD Player
Which component cables to use
the cables are fine labeled as they are you notice cr =pr, cb=pb and y is still y
the cables are fine and will deliver up to 1080I capabilities
Dec 09, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
TV w/ built in DVD
What a crock of **** this is guys! This FIX is surly a sad work around for the poor! Replace the mother board and solve your problem the correct way. No need to butcher up this TV. Better still, buy a name brand TV and a service contract which will save you money in the long run.
Dan Jackson - CET, which means Certified Electronics Technician
Dec 15, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Televison & Video Logo
1,245 people viewed this question
Top Televison & Video Experts
Electro Med Services...
