Question about Syntax Olevia 50" Rear Projection HDTV-Ready Television
New lamp still blinking red light
I replaced the lamp with a new one and it still does not work. How can you test a lamp to see if it is good?
I phoned Olevia and the Tech support said that if the Red light Flashes 3 times and the Green light flashes once and then this process is repeated - it means the Lamp is no good.
Tech Guy also said that this TV should never be placed near a Window/door - no sunlight!
My TV is doing the same thing and I need to get a lamp - they want $110 for the lamp.
Where did you buy the lamp from? How much did it cost?
Posted on Nov 06, 2008
When all three lights are blinking what do I do?
If the unit uses a ballast for the lamp, it could be that it needs replacement of the ballast.
Aug 25, 2017 | Office Equipment & Supplies
W KDS-R50XBR1 50 in. HDTV Television standby light blinks red 3 times
Something you might want to look at:http://sites.google.com/site/sonylcdrptvproblems/lamp-overheating-issue
Apr 06, 2012 | Sony KDS-R50XBR1 50" HDTV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
I turn tv on...green light comes on but i get no picture or audio....then light indicator blinks red
Hello!
Lamp or ballast(if lamp has been replaced) is bad.
Explanation: green comes on: system works, waiting for light to shine into light engine: no light is coming out of lamp, system shuts down, then you see red! how to determine: pull the lamp out of the unit's compartment. Inspect lamp: bloated stem? shuttered? reflector is not shiny? Chuck it!
Lamp looks good or just been replaced: try ballast. Close lamp compartment without lamp itself. Make sure, door is shut, as well. Turn unit on and listen close to lamp compartment: good ballast will make a buzzing noise, then stop. You've got "red'! No buzzing: ballast quit. Needs major repair! Lamp must be good, for sure, to get to the last part of diagnostics. Conclusion: more, than 2000 hours of usage: replace lamp first!
Good luck,
Alex.
Jul 29, 2009 | Panasonic PT-D5600U DLP Projector
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
How can I check if my new bulb is good or bad?
am sure the lamp is fine. first thing replace the lamp thermal sensor if this does not work check the lamp ballast (aka) lamp power supply.
Mar 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Zenith E44W46LCD new bulb still no picture
Could be an LCD drive board or a ballast. This is what to expect from free advice..... A guess. If you pay good money for a set why not get a factory tech. who knows what to do to solve your problem. I don't do LG warranty right now, but I did when your set was new. Here is a free gift. Start by having someone test the lamp tempurature sensor. It is a very thin black wire with a small fuse-like thermistor with heatshrink tubing around it. It is mounted on or around the lamp and can be purchased at any major consumer electrinics distributer. Good luck, Russmann.
Sep 26, 2008 | Televison & Video
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Televison & Video Logo
128 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
