Question about Sony Cyber-Shot DSC-F717 Digital Camera
DSC-F717 mp Question?
I have a F171 and I thought it was a 5 mp camera when I bought it. So why are all my pictures around 2 MP in size? I checked all the settings and it's all set to the highest setting too... Should I be using TIFF? Any help woudl be great.
    Master:
  • 551 Answers
Your camera is using jpg compression to reduce the picture file size. depending on settings, your file sizes will vary. fine compresses the least amount of data from the file, and produces the largest resulting files. std removes more data and so on. if your have your camera set to any of the jpg settings, you will notice that the resulting file sizes are not the same in a given setting. this variance has to do with the data it takes to make up each image. an image with a lot of blue sky (data that is essentially all the same across the sky) can compress to a smaller file than one that has lots of tiny detail through-out the picture. if you set the camera to produce a TIFF file it won't be compressed, and will be very large compared to the jpgs. it also takes forever to write the picture to the MS after you have pressed the shutter. I'm not that patient.
Posted on Sep 12, 2005
    Master:
  • 551 Answers
So long as you go into the menu, and make sure the Image Size selected is the one all the way at the top (2560x1920), and as long as you are taking shots in JPEG Fine mode, you're getting 5MP pictures! As the others mentioned, MegaPixels are different from MegaBytes.
    Master:
  • 551 Answers
I think that this is the normal size for a 5 MP photograph. Mine from the F717 vary from 1.8 - 2... MB. MP is not the same as MB. (pixels and bytes). Don't ask me to explain this, but the size of your pictures is all right.
    Master:
  • 551 Answers
Do you mean your files are around 2 mb (megabytes) in size? megabytes and megapixels are not the same thing..megapixelspixels=resolution and megabytes=file size..5MP pictures are around 2MB in size..
Image size too small - even when set on 5 MP
Hi, Although I prefer you getting it repaired, but there is a slight chance to get it working. 1) First you have to go through every single option in the Camera and change it. 2) Try using the Built-in memory instead of the external if you got any. 3) There is an option for the Picture quality, as "Standard, Fine, SuperFine". Try changing it. 4) Try using it on anothe PC just to be sure. If none helped, then a hardware component must be replaced, because there is not firmware update/upgrade. Good Luck
Jun 16, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
I have a Sony Cyber-shot DSC-F717 5.0 MP Digital Camera and when I turn it on I get a memory error. I have tried swapping out the memory but I still get a memory error. Any suggestions?
Try this:
First, make sure you have a copy of all important pictures i your computer.
Then, reinsert your memory stick into your camera and format it "using your camera".
Jun 16, 2011 | Sony Cameras
Good evening, I have a DSC F717 serial no 1749705. I lent this camera to my son some years ago and had it returned recently. As I tried to relearn my way around the camera I discovered that the image as...
This is known problem of ccd imager chip failure in DSC-F717 camera and ccd imager chip will be replaced to get correct live view in camera mode to take fresh picture.
Sony offers free of cost ccd imager chip replacement till March 31, 2010
Click Sony CCD Imager Support for details.
Thanks.
Feb 19, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
How many pictures can a kodek easy share m1063 take without a memory card
In your menu you will have a choice of "resolutions"(picture size) such as 9.0 mp,8.0 mp,6mp.8mp,5mp,3.1mp,2.2mp,2,1mp,1.2mp. The small the size(and poorer quality) that you choose, the more pictures you will be able to take. Your camera prob has internal memory of 32 mb and when you have selected your picture size it should show on the screen how many pictures you are able to take. Mine for instance will take 5 photos at 9 mp but 16 at 3.1. It really is worth having a spare memory card at all times to enjoy your camera fully.A 2 gig card gives over 1000 photos at 9mp.
Jun 12, 2009 | Kodak EasyShare One Digital Camera
Distorted/damaged pictures
Please check the image size (pixels x pixels) setting or the resolution (MP). Seems like the camera is shooting in low resolution. Have you used this memory card on a mobile phone or another camera? Format the memory card and try again.
Feb 14, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
I have a sony DSC-F717, and when i take pictues, the white colors on the image come out pink and other types the picture has like a green shadow over the picture.
Symptoms shows its start-up of CCD Imager problem in DSC-F717 and in few days, CCD Imager will not give picture data to camera circuit. CCD Imager is part which converts image in electronic signal and that signal / data goes to camera circuit for further process.
Sony will repair CCD Imager problem in DSC-F717 free of cost. Check Sony CCD Imager Support for details.
Jan 06, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
Size of JPEG file produced by this camera
the general rule is a jpeg is halve the mb of the resolution-6 mp =3mb file size-kodak uses a ton of compression and this is the main reason why-put a memory card in a kodak and you pick up about 20-30% more capacity than other brands!
Apr 06, 2008 | Kodak EasyShare C663 Digital Camera
DSC F717
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
Feb 17, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
79 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
