Question about Sony PlayStation Portable (PSP) Console
Usb connection failure
Hi my psp doesnot work on my pc .when i connect it by the usb chord ,it doesnt show up on pc monitor and keep flashing 'connecting please wait ' on the psp sreen
  • Anonymous Sep 01, 2008
    Same
  • 164 Answers
This is usually a problem that involves a fault in the USB cable. My suggestion would be to try a different USB cable and if that doesn't help try using it on another computer as it may be a fault with your USB port.
Posted on Sep 05, 2008
Hi, i have a PSP3004, firmwire carcked, everything was fine, unless once i removed the battery and reconnected after 15 mins. now i can't view my 8gb memory card on the PC (once connected...
You have to configure your USB connection to PC. What shows up as the drive in your PC when you connect your PSP to it is one of the 4 FLASH folders. Do the following;
1. In your PSP main screen, press your "SELECT" button and XMB Menu will show up. 2. Scroll down to the "USB DEVICE" option. 3. Loot at the value in the right, it should either "Flash 0", "Flash 1", "Flash 2", or "Flash 3". 4. Press Arrow Right until the value changes to "Memory Stick Value".
Exit and connect to your PC again and you'll see your 8GB MS this time...
Jun 09, 2011 | Sony PlayStation Portable (PSP) Slim...
I have an 12 year old hp printer still going strong hp deskjet 840c. Sometimes it shows a connection error that is the computer doesnot detect the printer I use a usb cable for connection. The printing...
Hi I think your printer has a parallel connector ( big D shaped socket with wire clips each end) on it if your pc also has a parallel plug get a parallel lead and install the drivers to use LPT1 this should remove the faulty USB plug from the problem
good luck Ian
Mar 25, 2011 | HP DeskJet 840c InkJet Printer
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
Got lead to connect psp to pc to download music to psp thought would work automaticly but i go usb mode on psp but cant link them help please
Hi deanocar,
Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. If it's not thisis how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 18, 2011 | Sony PlayStation Portable (PSP) Console
PSP Not Connecting to PC via USB
Hi rupasam,
Based on your concern, I suggest trying the following steps:
1. Before you plug it in make sure the PSP is in USB connect mode.
--> Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
2. Connect the PSP to your PC with a USB cable.
3. Press the "home" button on the PSP
--> at the lower left of the screen you can see the home button.
4. Use the left-right directional buttons to find "Settings", then the up-down buttons to find "USB Connection" on the PSP.
5. Press the "X" button, your PSP should display "USB Connection".
6. Please wait until your computer tells you that a new USB device has been connected, then show you a new generic hard drive, usually E: or F:
7. Click on the drive letter that corresponds to the PSP unit.
Hope it helps,
May 29, 2010 | Sony PSP (Piano Black)
Psp 300 doesn,t show the usb mode when connected to PC.It keeps showing Please wait .No problem with usb cable,port.
Hi rimoricky, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 16, 2010 | Sony PSP-3000 Silver Console
My PC cant find my PSP even im connecting with a usb device....
Sorry about this, your usb port on your psp could be possibly damaged. So you can use a memory stick on your memory card reader to do your data transfer. If you insist on using the usb connection then try seeing a sony repair personnel for this.
Regards
Aug 21, 2009 | Sony PlayStation Portable (PSP) Console
Computer does`t recognize psp
try to use another usb connector cable with your psp. It has some lost connection...maybe the data connector is loose. USB has 4 pin(pc side) the voltage supply for power and the data pin..just try.. if it doesnt work...checked if your in admin account because some hardware cant be installed if your not the admin of the pc.
Apr 13, 2009 | IBM ThinkPad R40 2722 Notebook
My psp cannot connect via usb mode
Hi rin1_02, Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. -->Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's notthis is how you do it: On themain menu, scroll all the way left to the "Settings" menu. Thenselect "System Settings." Then scroll to "Format MemoryStick" and press X. 2. Connect the PSP to your PC with a USBcable. 3. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Apr 07, 2009 | Sony PSP-3000 Silver Console
Psp problems
Hi Milez,
You probably have a power switch board failure or connection problem. Where the battery connects to the PSP clean that with a cotton swab and rubbing alcohol. Also see what you can do about cleaning the battery connectors the same way. If that doesnot fix it, you may have a cirucit problem inside. Click on the "Repair Directory" at the bottom of this screen. In the directory click on "Video Game Consoles" check with the repair shops that Fix Playstations to find a good deal on fixing it. Good luck
Nov 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
108 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
