Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Oil What oil type is recommended for my mower?
Usually straight weight, either SAE 20 or 30 weight.
Posted on Aug 31, 2008
Kohler courage xt7 lawnmower oil
You'll find the recommended oil (10w30) 'oil for kohler courage x17 mower' google search Hope this helps (of course they recommend Kohler oil but ....)
Nov 01, 2017 | Cars & Trucks
What type of oil filter do I need for a lawn tractor 24H.P. 46" mower Model #28857
Any good 30 SAE weight is recommended for grass mowers..if used with a snow blower use a good multi viscosity 10-30 or 5-30 ould be fine..good luck..
Jun 27, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
What type of oil do I use in this mower I got it second hand
SAE 30 is standard or 10w 30 for colder conditions plus works as an all round oil but may burn quicker so need to check levels more often with 10w-30, recommended to change oil every 25hrs use and replace filter every other oil change.
Apr 07, 2014 | Garden
What kind of hydraulic oil for woods 6200 zero turn mower?
There should be a label on the mower that lists the recommended hydraulic oil to use. I could not find the exact oil type for your model, but the label should be on the back of the mower.
If you are unable to locate the label, contact Woods support here:
http://www.woodsequipment.com/manualRequestForm.aspx
Oct 20, 2013 | Hardware & Accessories
What engine oil do I need for my yardman 6.0 HP push mower?
SAE 30 only; if using conventional oil. I recommend using synthetic engine oil. If you go with synthetic, you can use a multi-viscosity oil like 10W-30, but only use staight SAE 30 if using conventional oil. Many benefits to using synthetic oil. It cleans the engine as it runs, it provides superior protection and helps cool the engine parts better, and it almost assures you 100% that your engine won't fail because of the type of oil used.
Jun 18, 2011 | kawasaki Garden
Type of oil needed
Briggs recommends you use as SAE 30 weight oil if using conventional oil. Multi-viscocity oil (like 10W-30) is acceptable if using synthetic oil, that is 100% synthetic, not a blend.
Apr 05, 2011 | Briggs & Stratton Garden
Can you please advise which oil to put in my B & S rideon mower. Model 261777 Type 013801
Hi verndono,
Briggs and Stratton recommends to use SF or SG. SAE-30 or 10w-30 oil for temps above 40F (4C) , SAE 10W oil for temps between 40F (4C) and 0F (-18C) and SAE 5W-20 (or 10W oil diluted with 10% kerosene) for below 0F (-18C). I suggest you use 10W-30 or SAE-30 and you will be good to go. Hope this helps. Best regards. Denis.
Mar 01, 2011 | Briggs & Stratton Garden
Do it use mixed gas and what type of oil
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Today most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 20, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What type of oil to use when changing oil
For any four cycle engine (engines with separate oil and fuel fill locations) use high quality detergents in the following viscosity.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
(From the MTD answer pages). Best regards, --W/D-- Please feel free to rate my solution. Thanx.
Jul 25, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
325 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
