Question about HP (P2074-69003) Motherboard
Green light blink and off
I turn off my computer yesterday but today i try puting it back on the green light on the motherboard blinking is not stanble what might be the problem
am confuse here
  • 293 Answers
Hun, I really hate to be the bugger here, but its probably time to get a new comp. This computer is out of date by a long shot (as I can't even find the motherboard's user manual online.) I suspect that if there is a light blinking, it is blinking to the same as it's beep codes. So my suggestion is following this (as many key boards either have a small speaker for beep codes or they have an led for the same thing.)
Posted on Sep 01, 2008
  • Kristoffer Martin Sep 01, 2008
    correction (sorry its late) I meant motherboards*
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
Computer will not power up. there is a green blinking light on the motherboard.
did you try to uplug and plug back up?
i had that problem.
it was a short(i know because i cause the short)
i had a old motherboard dell celeron 2.0ghz and i just was bored and started touching metal to metal and it started to blink so check your motherboard
May 22, 2009 | HP Pavilion a350n PC Desktop
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
What else the blinking green light
Please research this more before asking a question! There are 4 caps in the DM module that need to be changed. It DOES require some technical skills and soldering experience. If you still have not found the answer to this problem, let me know
Sep 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking red light at "on" button
Dont panic the date is more than likely fine was the computer off or on during the night. The three flashes is usual joined with 3 beeps chweck that the internal speaker is on. Second there is a small battery on the motherboard. Disconnect the power then take the battery out for twenty seconds then put it back in be gentle taking it in and out the reconnect the power then see if the unit boots if not. At worst you can take the hard drive out of the computer and put it in another and retrieve the data.
Hope this helps :-)
Aug 15, 2008 | HP Compaq Business Desktop d330
Power doesn't turn on
NO! Do not buy a new motherboard or pc without checking some things.
First, is the green light you say is blinking on the Power Supply itself?
If it is, then the power supply is dead. A blinking light on a PSU means that it can no longer hold a charge and needs to be replaced. Get a new one and pop it in.
Mar 10, 2008 | HP Pavilion A730N (PJ510AA) PC Desktop
HP (P2074-69003) Motherboard Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
