Question about Intel D845GVSR Motherboard
System not booting
I already checked both these possibilities.
I also tried booting another working system with my
hard disk that also works.
I also checked the RAM that is also working on another system.
I think the bios itself is not loading.
    Problem Solver:
  • 8 Answers
Just go to the intel webpage and download the latest bios for ur motherboard put them on a floppy and install them then try booting ur pc... this should work
Posted on Sep 02, 2008
My emachines e350 won`t turn on it alweys says No bootable device--Please restart systam and I do that and it says it again
Check that you have not left a non-bootable CD, diskette, or DVD in the drives of your PC, nor have any USB devices plugged in that the system might be looking to try to boot from.
If the above check is clear, then go into the BIOS settings and check that your internal hard disk drive is set as the first boot device or is ahead of any other disk drives you may have installed.
You cannot connect computers to each other by just using a standard USB cable - it doesn't work that way.
If you still cannot boot from your internal hard drive, then you should consider downloading a copy of Hiren's Boot CD (which is a CD .ISO image) then burn this to a real CD and try booting from that media - you may have to select the CD as a boot device in your BIOS or if you get a boot options menu.
If you can boot the Hiren's CD ok, then your internal hard disk may have failed - you can test this with the DOS Programs of the Hiren's CD by selecting Hard Disk tools then selecting HDAT2 which will try to find any installed hard disks then allow you to test these and repair problems if possible.
Jan 01, 2012 | Computers & Internet
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
Appear 020326 and PXE-E61 PXE MOF: exiting PXE ROM
Actually your computer is trying to boot from network. When you turn on your computer, enter the BIOS setup.
Change the boot device priority. The recommended setting is to put your CD/DVD-ROM Drive as 1st boot device.
Also disable the 'Network Boot' if possible or else put it as the last boot device.
After this step, press F10 to save and reboot. if you get a "No operating system found" error, try booting from CD and repair Windows.
If problem not resolved, remove hard disk and put it back.
If problem persists after these steps, test your hard disk on another laptop to check if it is OK as it may be a hard disk problem. If it does not work on another laptop, consider replacing it.
May 10, 2011 | Computers & Internet
Boot disk failure no hard disk found
The error means that your system is not able to detect the hard drive on the system, check if the hard drive wire connections are tight and not loose and then try rebooting the system.
Look for hard drive stats on POST whether it succeeds or fails. This is how you can do that.
When system boots up, press the PAUSE?BREAK on the black screen and see whats system comment for your hard drive power test. If it succeeds and your hard drive's connections are also tight then possibly your hard drive might have crashed ( which means there are bad sectors on the hard disk).
Try performing disk checking on the hard drive to see if there are any bad sectors on the hard disk, the disk check will automatically fix the soft errors but if the errors and hard errors in that case the disk checking utility will not automatically fix the errors and you will need to get a new hard drive.
Thanks !!!
Nov 22, 2010 | Computers & Internet
My computer just shut off and now won't reboot
You may be able to boot in safe mode and discover the problem that way. You may want to check the battery, and the power cable, but I assume you already did that, so if the safe mode reboot wont work, it is possible that the hard disk crashed, or you have another hardware problem. Try booting from a windows install CD, or a Linux CD, to see if it can boot at all. Then you may be able to see the hard disk and determine if it is crashed or corrupted. Also, sometimes removing the battery and pulling the power cord out for a few moments can allow it to restart.
Sep 12, 2010 | HP Pavilion dv6000z Notebook
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
Does not show up in my computer but does in bios
Can you boot the computer from a boot floppy?
If so, try and partition and format the drive with fdisk and format.
May 20, 2009 | Maxtor DiamondMax D540X (4D060H3) 60 GB...
The system won't recognize the hard drive to boot up. Is there a boot disk so I don't have to do a system recovery?
Please try to unplugged your HDD for a short period of time, let it cool because there's possibility that heat temperature affected the drive, which I likewise encountered in my PC. also, please check the cooling system of your PC, if it's possible install additional exhaust fan. regards
May 11, 2009 | Computers & Internet
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
The laptop will not set-up it comes up rune normal/ safe mode / from last point that worked but none work what shall i do?
Sounds possible that you have damaged sectors on your hard drive, or possibly a faulty hard drive. I am assuming here that you have Windows XP
Do you still have the CD's that came with the PC with the windows operatings system on them - I would try to boot from the Windows CD and run the set up utility but choose the repair option if possible
Your computer must be configured to start from the CD drive or DVD drive. which you have to choose in the setup fuction by booting the PC and hitting the F1 key as the PC starts to boot - but check you PC manual to make sure thsi works for you. typically PCs are usually set to check other boot devices first so you may be good to go regardless.
When the "Press any key to boot from CD" message appears, press a key to start your computer from the Windows XP CD.
When the "Welcome to Setup" screen is displayed, press R to start the Recovery Console.
When prompted, type the number that corresponds to the installation of Windows that you want to access from the Recovery Console, ( you may only have one installation and it may already be selected) and then press ENTER. For example, if you have one installation of Windows on your computer, type 1, and then press ENTER.
When prompted, type the Administrator password, if its your PC and its stand alone you may have never had an administrator PW so you may just press ENTER.
Then choose to repair the installation. Once the system loads the files - take the CD out and reboot the PC.
Hope it fixes it, but if the disk is really damaged it may need a new hard disk.
Regards
Aug 28, 2008 | Computers & Internet
Intel D845GVSR Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
