Is the vehicle out of gear and in the park position? if so try and turn the steering wheel left and right at the same time turn the key back and forth slowly. repeat this proccess several times. also move your shifter back and forth several times slowly. if this doesn't solve the problem, there is a pin inside the steer wheel coloumn that is the problem. you will have to remove the steering wheel column covers to solve this. good luck ....please rate this.......thanks
