Question about Frigidaire ATF6000ES Front Load Washer
Softner dispenser the detergent dispenses but the softner does not. I have removed the tray and cleaned it thoroughly.
  • jruzic1965 Sep 24, 2008
    Have you been able to fix this problem? Nothing I do works. Please let me know how youfixed the dispenser issue.
    Jennifer
    Novelist:
  • 166 Answers
Bad censer!
you need hands on experienced service!
Posted on Sep 07, 2008
LG washer detergent dispenser won't open The dryer is on top of washer
if you are patient, if you are lucky, you can take a very flexible tool like a frosting spatula and work it into the right hand side of the dispenser drawer and work it back and forth while moving the drawer in and out from its stuck position and maybe get it over the top of the softner tray and free the drawer. the top of the softner is popped up a bit and is catching on the top of the dispenser's enclosure top. about an inch or so in from the right. takes luck, skill and most of all patience. not easy but maybe less work than removing the dryer and going into the top of the washer. (if you get it out, then thoroughly clean everything up, then file down the front of the softner cup so it will not happen again--or throw away the softner cup and stop using softner) GOOD LUCK
Oct 20, 2016 | LG Washing Machines
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
Detergent dispenser does not dispense.
see the causes and remedies:
Most dispenser problems are due to being gummed up with detergent, fabric softner, bleach residue, and water deposits. First check the dispenser drawer by pulling it out of the dispenser itself. To do this push down on the tab in the back and remove. Check that all is thoroughly clean. No holes blocked up. Now there are several types of dispensers out there but most have holes in the top where it dispenses hot or cold water to the appropriate area. These holes can become plugged up. If you have really hard water I would say replace the dispenser if it is gummed up bad. Otherwwise remove the dispenser and thoroughly clean it out. Before doing this check the solenoids that allow water through the dispenser. The solenoids can be checked with an ohmeter but if all is clean and the solenoid does not open to allow flow replace the unit or solenoid. Connect your ohmeter and refer to the tech sheet or service manual for the proper reading. You can also check for voltage going to the solenoid. If you have voltage when each solenoid should be working, example: When the machine should be dispensing fabric softner, The solenoid that allows water to flow through that area should have voltage. If it does replace the solenoid or unit.
see the diagram attached
God bless you
Jul 18, 2012 | AEG L74650 220volt 50hz 7 Kg Capacity...
GE WSXH208AWW doesn't dispense detergent, softner or bleach. Dispenser is totally dry after wash cycle.Appears no water gets to tray.
I'm having almost the same problem - the bleach & softener both will NOT dispense, but (LUCKILY) the detergent does dispense on mine, for now.
In order to get the solutions (bleach, softener, detergent) to go into the washer, the water needs to pour through the dispenser somehow. Dry means NOT working (mothmanmeg).
I need help, too!! We tried taking the drawer out & cleaning, no luck.
Apr 17, 2010 | GE WSXH208A Front Load Washer
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Sep 09, 2009 | LG Washing Machines
Bad leak
Your first option before anything else is to remove the dispenser tray entirely and clean it thoroughly.
Also clean inside where the fits before replacing.
Quite often there is a build up of old fluids or powders that have congealed and blocked up the inside.
Good luck and thanks for using FixYa.
Mike.
Mar 02, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Bleach and softener dispensers filled with water at end of cycle
Yes, remove the dispenser tray by pressing on the button on the softner and pulling out tray completely. Now lift the flap over the softner compartment and clean thourougly with hot water, making sure all tubes and holes are free from residue softner/detergents. Replace flap by making sure the bigger tube fits OVER the smaller tube and click into place. Replace tray. Water is present due to the "syphon effect" of the dispenser not working, caused by residue detergents blocking the tubes/holes. Oshie
Oct 28, 2006 | Bosch Nexxt Premium WFMC6400UC Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
95 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
