Question about Lexmark X1270 All-In-One InkJet Printer
I cant run the download on my computer for my lexmark printer
I download the software for lexmark printer. When the download finish my computer run an error of aioc
  • Anonymous Sep 07, 2008
    i have download the cd on my computer till clisk finish but it says no communication detected between printer and computer
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 29 Answers
First, you'll need to install the software and driver for this printer:
  1. Make sure you have the regular printer driver installed. If you don't, you can grab it from the Lexmark website and install it.
  2. Next, keep your USB cords plugged in but turn your printer off.
  3. Download the All-In-One Center Software here.
  4. Unpack the archive, open the "Applications" folder, anddouble-click Setup. This will install the application - it can take abit.
  5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
  6. If you get an error when running a test scan, don'tpanic.Reinstall the regular printer driver, using the "Update Driver"optionthat appears.
  7. Restart your computer.
  8. Do a new test scan. This should bring up the All In OneCenter'sloading screen, which will start searching for programs (thiscanreallllly take a while). When it's done, everything will beworkingbeautifully again!
Then, hit Lexmark's site for the Setup Sheet and User Guide available here.
Posted on Jul 07, 2009
  • Katy Swush Sep 14, 2010
    Please can the above "lolaness" please put up a link that works for the same problem as above - i just want to download the all in one centre PLEEEEEEEEEAAAAAAAAAAASSSSSSSSEEEEEEEEEE im at my wits end! It says that it has been removed as it has not been used in a long time - any other ideas please
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
Message no lexmark X9575 fax printer installed
Hi. Try to use and install the software again using the installation cd. When it runs, it should pop up the window with 3 options: Install a printer, Update/Upgrade, or Install additional softwares. Choose install additional softwares. In the next window, place a check mark in Fax solutions. Then, continue and finish the installation. If you don't have the cd, software can be downloaded by going to this link to the Lexmark website. http://bit.ly/d9TDnb . Download the compatible driver for your computer. Run the installation. Hope this helps.
Mar 09, 2010 | Lexmark X9575 InkJet Printer
How do i install my lexmark X2500 printer without my installation cd
Go to to the Lexmark Website. Or better yet, click on the link here: http://support.lexmark.com/index?page=recommendedDownloads&locale=EN&productCode=LEXMARK_X2500&segment=DOWNLOAD&userlocale=EN_US#1
where you can download the software you need. Depending on the version of WinXP/Vista or Win7 your computer is running simply pick the correct choice on the site, download and install before you plug the usb cable and don't plug it in unless directed to do so, or if the software installation finishes.
Dec 14, 2009 | Lexmark X2500 All-In-One Printer
Cant find disc to install printer to computer lexmark x8350
Go to the Lexmark website. Click on the support link; lookup your specific model # and select the operating system you are running. The software/drivers will be listed for free download. Download, install, and reboot and you should be all set. Hope this helps.
Aug 26, 2009 | Lexmark Inkjet Z517 Photo Printer
Were can I find install help for my X83 lexmark lost my CD
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
May 23, 2009 | Lexmark X83 All-In-One InkJet Printer
Cant hookup z600 printer
If you do not have the software CD, you need to download the software from one of the following locations, by clicking on links below and selecting the model in page:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Feb 14, 2009 | Lexmark Z600 InkJet Printer
Installing to second computer
Hi Cathy, script errors fall into the (Software did not install correctly issue, most common). Uninstall the printer software from the notebook. Than go to the link below & download this registry cleaner.
(Its free).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
Once finished restart your notebook. Install the Lexmark software from the CD or download it from Lexmark, there (may) be some updating within the downloaded software. http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:463:0:0
Click the above link. Pick your operating system & the link to download will open.
Good luck Cathy!
Mike
Oct 03, 2008 | Lexmark X7170 All-In-One InkJet Printer
Lexmark software help
Check with lexmark.com, they may have an updated download for you.
Aug 13, 2008 | Office Equipment & Supplies
Lexmark Z600 printer
I would download the latest software from Lexmark and install since you did a full recovery.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:389:0:0
MM85
Jul 26, 2008 | Lexmark JetPrinter Z605 Color InkJet...
I have a lemark x1100 series all-in-one. I need a driver for my computer so I can use it on my computer. The wizard couldn't find a driver and I lost the disk that came with it. My computer has windows...
Here is the download page.
Click and download software into my docunent,
when finished run software installer from my documents.
Unplug printer usb cable before and during software installation, this is important.
Jul 23, 2008 | Lexmark Office Equipment & Supplies
Lexmark X1270 All-In-One InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
