Have a few 650s, all setup to sync E-mail and Calendar with Corp Exchange server over the air. One of these devices is NOT syncing calender entries made on the 650 back to the user's Micrsoft Exchange/Outlook User's calender. It syncs fine if the calendar event is entered in Outlook and syncs to the 650, but not vice versa. I cannot find anywhere to correct the problem.
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/ * Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955 * Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above. * Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange * Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty. * Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept. * A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
It CANbe setup to send and recieve emails from email services using the POP3 or IMAP protocols. Too quote:
VersaMail's easy account setup wizard will get your mail accounts configured in a flash. The intuitive design will make you a power user in no time.
Get your email on your schedule. Stay on top of your life with Auto Sync: get business and personal email automatically downloaded to your phone based on a schedule you specify, and new mail alerts based on your preferences. The VersaMail® email client supports up to 8 email accounts, including Yahoo!, AOL, and Gmail.
Access corporate email. Using built-in Microsoft Exchange ActiveSync, wirelessly sync Calendar, Contacts, and email with your company's Microsoft Exchange Server 2003 (access enabled by your IT administrator). Or, access business email using POP or IMAP and a compatible Virtual Private Network (VPN) client (sold separately).
You may have tried Exchange ActiveSync in VersaMail
When you setup an Exchange ActiveSync account in VersaMail, you are asking your Treo to synchronize email and your calendar with an Exchance 2003 server. In order to prevent duplicates, VersaMail disables Calendar synchronization via HotSync while the account exists on your Treo.
So if you are an Exchange ActiveSync (EAS) user, you have a choice; you either sync wirelessly or you can delete the EAS account in VersaMail and can then sync your Calendar via HotSync. You cannot do both unfortunately.
OK. Hope this helps you because it fixed my problem. Go into palm desktop. Go to hot sync, click on custom Go to Calendar (Outlook) and double click on that. At this point click on settings. Under conflict resolution choose "outlook wins". Then go out and check syncronize files and set as default. Click done and this should resolve the issue. Reply if this is confusing.
I was tring all the possible ways to resolve the issue. At last got a solution for my problem. Hope this will work for you all. Download the "OutlookConduitUpdater.zip" and install. This will resolve the calender "do nothing" while sync.
creat new calendar.
Your msoutlook has a problem.
Try this turn around.
PC SETUP:
ON MSOUTLOOK
click on go to menu
tap on FOLDER LIST to reveal the listing.
On the outlook today tab
right click and creat new folder - with calendar entries
ON HOTSYNC BUTTON
Go to Custom
Highlight calendar tap on change
tap on Settings
On setting tap on browse
then choose the new calendar you created.
tap OK and set as default.
then do a hotsync
Yes you can.
You can sync to public folders using Chapura’s Keysuite, which allows you to choose the folder (or folders) you want to sync to. I have been doing so for years with different Treos, and in fact their synchronisation software is much better than that which comes with the Treo 650.
Tryy this -- Go to Chapura.com and purchase the pocket mirror software. I have Sprint service and that additional software has resolved my synch issues.
Have you setup an EAS account in VersaMail?
The VersaMail application on your Treo 650 supports Exchange ActiveSync, which allows synchronization of Email and Calendar wirelessly with Exchange Server 2003. If an EAS account exists on the handheld the Calendar conduit will disable itself to avoid duplicates.
Go to VersaMail on your Treo650
Select Menu: Accounts: Account Setup
Check to see if any EAS accounts exist on the device by selecting and account, then Edit...
One the first screen check Mail Service. Do any of them say "Exchange Activ..."
If yes you'll need to delete that account to sync calendar entries.
