Question about Refrigerators
I have purchased a new start/run selenoid for my GE ref, but the capacitor on on backorder. How do I check the one I have in order to determine it is bad. I put an ohm meter to it and it show very high internal resistance, but is that the only way to test it?
  • 62 Answers
You usually don't need the new cap. The old one will work as long as it isn't shorted or have low resistance. It seems that the one you have is ok. Note that the cap is a run cap and is used to help the unit run a little more efficently. The unit will work fine with out it, but should be used. The resistance check is good way to check it, the other way to check it is with a capacitor checker.
Posted on Aug 31, 2008
Cant get new HDMI board for Onkyo TX-SR604
It's usually the hdmi switching IC that goes bad on these. Not something you can really replace without the right equipment and knowledge.
Jul 10, 2013 | Onkyo Tx-sr604 7.1 Channel A/v Receiver...
New house, cooler bought 2006. doesn't seem to run, but light is on
If the compressor is not running you will need to replace the "start relay" and the "run capacitor" on the compressor.
Here is the start relay to order.
Here is the capacitor to order.
Here is a diagram to show you the part locations.
The start relay is number 89 on the diagram and the capacitor is number 96.
The parts come with a 365 day, any part, any reason return policy.
Nov 09, 2012 | GE ZDBC240NBS Beverage Cooler
What capacitor should I order for my outside unit.
the starting capacitor was connected at the one line of the compressor motor then the value was label at the body of he capacitor, like 450v/ 5uf. to determined that the capacitor is totally worn out you will need a analog tester or a capacitance meter. usually if the starting capacitor get bad the motor doesn't run or hard to rotate.
Nov 05, 2012 | Heating & Cooling
Ref just clicks
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Sep 24, 2010 | GE GSH25JFR Side by Side Refrigerator
Just quit working everything seem to be fine, checked continuity on compressor, o.k., but can't hear it start, and the lines to and from seem room temp.
The first place to start is with the power off, place an amp clamp around the "common" wire from the compressor. Now turn the power on and check what your amp draw is. If there is no amp draw, then the compressor is not running. Why is the compressor not running? When you say you "checked continuity of the compressor, ok" I take it that you found your run, start, and common windings, and that by doing a little math you determined everything was good. If this is the case, then check to make sure the capacitor is good, and any starting relay that might be used is in correct working order. Hope this helps
May 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We ordered a GE gas cooktop 2 burner module to replace the grill on the lefthand side of a cooktop we inherited (model JGP389WEVWW). The gas cooktop only had 2 burners with a grill, and since we want 4...
Sep 26, 2009 | GE Cooktops
U-Line combo 75 not getting cold
hi there,
i have some procedure in troubleshooting a ref., as follows:
1. check if the compressor will run when you plug the ref in the outlet/power.
a. if the compressor run and it will not produce the cold or heat. then the problem is, the system of your ref. has a leak. it lost all the freon charge into the system. find a near service center in your area.
b. if the compressor run and it stop. unplug your ref. from power.
  • check the capacitor if it is ok, using a multi tester. by determining a good capacitor in resistance test at 100 kilo ohms or 10 kilo ohms the pointer will deflect to right and it will slowly going to left or a higher rating. bad ca[pacitor pointer steady in zero position or infinite.
  • but if the capacitor is ok then some trouble in mechanical parts inside the compressor. specially when you turn on your ref. you feel some surge power from the case of the ref. find a near service center in your area. if you need to replace the compressor and some parts of it.
c. if the compressor will not run, unplug your ref from power and then check the follow:
  • check the compressor resistance by using a multi tester, open the terminal box of the compressor. have some checklist in the terminal setting that has a letter symbol R (running) connected to what color of wire, same also with S (start) and C (capacitor) check in its terminal resistance.
Nov 29, 2008 | U-Line Refrigerator Ice Maker
Won't start
its either a bad or drained battery or the starter selenoid. check your battery voltage using a tester or put it on a charger, if that doesnt solve your problem you should look at your starter selenoid
Nov 27, 2008 | 2006 Harley Davidson XL 1200 R Sporster...
Mco153ub microwave
You can order the door handle here, but it may be on backorder.
You'll have to check back or contact them directly about backordering it for you.
Sep 11, 2008 | Microwave Ovens
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
