Question about LG 42PX4DR 42 in. Plasma TV
Lg 42 in plasma ihave a 6 in discolored line acrossthe bottom of the screen. can it be fixed
  • i have a six inch foggy line across the bottom of my screen can it be fixed fora reasonabe price?
  • 106 Answers
Two causes for this failure.
1. The Y SCAN board or YSUS board failure. Your can replace the failed boards with reasonable price.
2. The PDP Panel failure. Very expensive to fix this failure.
Good Luck!
Posted on Sep 01, 2008
I have a single thin horizontial black line six inches from the bottom of the screen. how can it be fixed.
Hi.
The line is probably in correspondence of the low Y buffer board, located inside the TV and connected to plasma display. In that case the board must be replaced to fix the problem. One of the symptoms of a defective low buffer board is a black line that starts from the bottom of the TV.
Regards.
Ginko
Apr 25, 2011 | Maxent MX-42HPT51 42 in. Plasma TV
I have a problem with my lg 42pq30 plasma, it has vertical lines distortion across the screen. does anyone know how to fix this problem
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
Feb 04, 2011 | LG 42PQ30 42 in. Plasma TV
There is a horizonal line across the screen about an inch wide, can this be fixed, how much and how hard
plasma control board defective,or plasma display defective. Solution is go to the repair store, normaly is the diagnostics is " Buy a new one"
Oct 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Shaking lower half of the screen worsens with time on
Hi, Suggest to take to a local Tv Repair Shop. Thanks.
Sep 22, 2009 | LG 42PC3D 42 in. Plasma Television
A black single line about six inches from top of television all the way across the screen.
Take the TV Back....bad transformer in it, not worth fixing unless you're under warrantee or have extended service plan. Replace if you can as NORCENT is bottom rung of these types of TV's. If you don't know or haven't heard of them, don't buy them...from a guy who sells these things!
Apr 26, 2009 | Norcent Technologies PT4231 42 in....
Red in picture
Have you tried with a new scart or htm lead?
Sep 23, 2008 | LG 50PX4DR 50 in. Plasma TV
LG DU-42PX12XC
sounds like bad y driver, if so very very repairable
Mar 21, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Black vertical lines
ey there. have you solved this thing yet? you might want to check out this DIY plasma TV repair blog. there's a video on how to fix this.
Jan 23, 2008 | Samsung PPM42S3 42 in. Plasma Television
LG 42 PLASMA
check all inputs on tv ,also check if menu on tv is working ,make sure lines arent being produce by another source, cable box etcc..If menu and or OSD are affected .Then there is a good chance you have lightning damaged some where in signal section on tv .
Dec 03, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 42PX4DR 42 in. Plasma TV Logo
177 people viewed this question
Computer Repairing
Computer Repairing
