Question about HP Pavilion ze2000 Notebook
Charging problem I have a hard time getting my adapter to charge my laptop. The thing in the charge hole is loose. Is this fixable? I have gone through 2 AC adapters and don't know what else to do. Thanks
    Novelist:
  • 72 Answers
My answer:
I charge $100 flat rate fee to either re-solder and/or to replace (as in your case) the broken power adapter jack on the laptop mobo with a new jack. Any other further mobo damage (if any is present) would have to discussed at the time of initial inspection upon receiving your laptop here. More times then none the jack mobo support pins (usually only 2 if a cheaper board design, or 4 pins if a better quality design) are broken off and the +/- adapter jack contact pins on the mobo come loose solder-wise from excessive movement. If the new jack replacement part has to be ordered special then it usually only takes 2-3 days from my electronics parts supplier locally here.
Continuing to use the laptop in this manner chances the risk of frying the mobo should that broken jack short out or cause a current spike surge to the power supply!! Choice is yours - so use your better judgment here.
You would have to also pay for USPS shipping both ways from Anaheim, CA.
Thx,
Frank
Posted on Aug 31, 2008
    Scholar:
  • 71 Answers
My shop charges $190 to resolder a new inside connection (if possible. need to see inside)
Replacing a motherboard is the price of mobo + 2 hr labor ($95/hr) = $440
I would test and make sure there's not a short in your power cable. Use a voltmeter and hold + inside and - outside and move the cable all around and see if it drops in and out. Other than that...it needs to see a shop.
James Mac
Acer 4720Z not charging, suspect loose connection
The hard way is to seek out the location of loose connection and then soldering it out.
Many electricians will be able to help you out.
Temporary solution is bending the cable or squeezing it with prongs and all, but as I said, they are just temporary and you'll have to keep bothering with it again and again.
So if don't want to get into that hassle, I recommend getting a new charger.
Oct 06, 2013 | Acer Computers & Internet
Acer 4720Z not charging, port is not damaged neither pin
Check if the led indicator is on, when you connect your adapter to power outlet. It may simply be loose connection between the adapter and connecting cord.
If possible, borrow adapter of same make and model from someone (maybe a friend who owns the same laptop) to ensure, that the port is not damaged.
If the port is all good, I suggest you get your adapter replaced, as repairing it is not worth the hassle.
-Meet.
Baterry isnt charging it only works on AC power DELL PP22L
Press the function and F3 button. This will enable/disable charging. If that does not work, then you either have a power adapter that is not creating enough voltage to charge the battery or the battery has gone bad.
Oct 21, 2012 | Dell PP22L-XT279 Core 2 Duo 1.6g 1gb Ram...
COMPAQ V2000 BATTERY NOT CHARGING
Try to isolate the problem first. See whether it's a laptop issue or an adapter issue. If the adapter has a light, see if the light is coming on when you connect it. Also see if the laptop works if you remove the batteries and connect the adapter.
There could be several issues here:
1. Your adapter's light may be coming on, but it still might not be delivering power to the pin. If you have a multimeter, connect it to the terminals of the charger and see if you get a voltage reading; if not, there may be a problem with the cable running from the adapter to the laptop or the adapter itself may not be giving the right voltage.
2. The second possibility is that the adapter is OK, but the laptop's power connector is faulty. This will require a technician to remove the old connector and solder a new one into place.
3. If both the adapter and the connector are fine, then the problem is most likely with your charging circuit, which is inside the laptop. This circuit powers the laptop through the batteries, and will once again have to be inspected by a qualified technician.
Hope this helps
May 24, 2011 | HP Compaq Presario V2000 Notebook
Hi i have this problem i dont know if its bad or not but every night i turn off my lap top and let it charge over night then this morning when i log on to my user my battery says 4% plugged in, not...
This can be a couple of things. The battery, the charger, the internal charging circuit, or the connector.
The battery is not that old but just enough that you could see problems depending on how you use or charge. If you drained it a lot or never used it on the battery this can happen. If the battery was the problem then you would see very short run times when it was fully charged. For example it may run down in say 10-15 minutes or less. The battery may still be under warranty. If you feel a hot spot on the bottom of the laptop after charging overnight this usually means the battery has a problem. The heat is from the charging circuit working pretty hard.
The adapter or charger can be bad but rather rare for it to happen. Usually they work or they don't. Again should be under warranty.
The internal charging circuitry can be having a problem. Not common at all but it happens. Again will be covered by warranty.
Last is the charging plug. This is the connector where the adapter plugs into the laptop. If the plug has been damaged or is loose it won't charge properly. The way to check this is to plug the adapter in and then gently move it around if the plug moves or doesn't feel secure then this has a problem. Usually when this happens the lights on the laptop may flash off and on as it makes proper contact. This may be covered under warranty. When it isn't they will say it is user abuse.
It may take you a bit of watching to see what the problem is. It could be a one time thing ie the connector wasn't plugged in right. It can be a bad battery. Batteries can go quickly but normally they fail fairly slowly over time. You need to check if you have warranty. All of this should be covered on a ~18 month old laptop but you may only have had a 1 year oem warranty.
If you have to pay for anything a battery is $40-$80, a power adapter about $50. The charging circuit requires a new mainboard and the plug depending on the model either requires a new mainboard as its built in or the plug is a seperate piece which can run from $5 to about $100. The battery and the plug are the most common cause for this type of problem.
Sep 05, 2010 | HP Computers & Internet
Dell inspirion 1501 laptop, not charging battery light showing red, have bought a new mains adaptor but still not charging
Does the back dc jack seem loose when you have the ac adapter plugged into it? Wiggle the cord right where it plugs into the laptop. If it moves around then most likely the dc jack on the inside has one of it's 3 points of contact broken. This means that someone would need to re-solder that contact or put a whole new jack into the laptop. Another thing to try is replacing the battery. Sometimes they won't charge because they are bad. Another thing to try is take the battery out, plug it into the adapter, turn it on, get into windows, shut down, put battery back in, turn on. See if that resets the battery and makes it charge.
Apr 30, 2010 | Dell Computers & Internet
My laptop won't turn. on at all
the first thing you have to do is make sure your charger does not have a short in it. then blow out the charger slot. plug in your cord and check to see if the charge symble is on if it is not on then you need a new charger cord. if it is on wait for about a half hour checking periodicaly to see if it is still charging. try to turn it on if it does not work you need to replace your battery do not buy a new laptop this is a fixable problem
Feb 07, 2010 | Compaq Presario CQ60-220US PC Laptop
My inspiron 1525 is not charging. Have replaced battery and charging lead and still does not charge.
Based on what you have stated, you replaced the battery and charging lead but the laptop still won't charge. What do you mean by charging lead?
Are you referring to the power adapter?
Since you already changed those two things, then the problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Inspiron 1525 Laptop Jet Black
My Ibm thinkpad r52 wont charge. The battery has a very minimal charge left on it and i can turn the computer on and it start booting up for about 10 or 15 seconds.
This could be due to one of 3 things:
Your battery could have gone bad. They normally have a life of perhaps 3 years, but shouldn't suddenly just quit. They gradually have less and less time between charges.
Second, it could be your power adapter. Get a voltmeter and take a reading of the voltage that comes out of it. Should be around 18 volts, If I remember correctly.
Third: It's the motherboard--the charging circuit in the computer itself.
So--if it suddenly quit charging, the battery is "probably" not the problem. Now rule out the adapter. Finally, replace the motherboard.
Jul 23, 2009 | IBM Computers & Internet
Seems like power source in back of 1150 inspiron is loose
appears to be a loose connection between the AC adapter and the computer. Inspect the port on the computer where the AC is being connected for any damaged. If available, try using another known-good AC with your computer to isolate if the problem is specific to the AC adapter. If the same thing happens with another AC, the motherboard needs to be replaced. If the warranty of your computer is still active, contact dell and request a replacement for the motherboard
Feb 02, 2009 | Dell Inspiron 1150 Notebook
HP Pavilion ze2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
