Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Jenn_Air Oven Problem
Our Jenn-Air Range is Model D156 or S176; I suspect it is an S176, because ours is a "Slide-in" version. When we push the button for "Bake," or "Convection Bake," everything looks normal for several minutes. After the dial is turned to select the baking temp, the Digital Read-out indicates 140 degrees, as is normal. The indicated temperature should begin to increase until the desired temp is achieved, (at which time, the oven beeps). Most of the time now, the oven malfunctions and turn off. This morning I had make repeated attempts to start the oven. It took about 9 or 10 tries before the temperature reading began to increase. If the temp ever starts going up, it will complete the baking job just fine.
  • 943 Answers
HI thanks for your question. A common problem with gas ovens is that the oven will not get hot enough. and the part that's at fault is the ig niter. replace the ig niter. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
Jenn-air jdr8895 sabbath error
Faulty range/oven parts aren't the only worry a gas range owner has; the threat of carbon monoxide is very real and should be paid close attention to when doing repairs on the range.
If your range or oven gives off soot, you definitely have a carbon monoxide problem. Soot is the result of inefficient or incomplete combustion. There are always elevated levels of carbon monoxide with soot production. Properly adjusted range/oven parts do not give off soot. You may have poorly adjusted gas pressure, the air shutter may need to be opened, or you may be supplying fuel the oven isn't designed to handle. Don't use natural gas in liquid propane stove or vice-versa.
Increase Engine horsepower.
Jun 02, 2012 | Jenn-Air JJW8230D Electric Double Oven
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Our oven starts beeping and then displays a F 1 code and shuts down.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 12, 2011 | Jenn-Air Ovens
I need to replace the hinge receptacles on a Jenn-air wall oven (WW30430PC). How do I access those parts?
The only way to replace the hinge receptacles is to pull the oven out of the opening. If you need parts you can get them on the link below. Also if you call the link below they will walk you through on how to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=45883&diagram_id=28594572#d28594572
May 16, 2011 | Jenn-Air Ovens
JennAir F8
Check out www.appliancetimers.com They can rebuild your clock for around $100. A new Jenn-Air is like 2 grand.
May 21, 2010 | Jenn-Air JJW8530C Expressions Collection...
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
Broiling
Usually you need to turn the temperature to broiling (high), some require the door to be open about 2 inches (assuming yours has a detent (hold) there.)
Apr 25, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
250 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
