Question about Frigidaire ATF6000ES Front Load Washer
Foreign object in soap dispenser
A small bottle stop dropped into the soap dispenser and I was unable to retrieve it before it fell into the tube in the far back part of the tray. Is there a screen that will catch this bottle stopper before it gets into the pump or other parts of the washer? How can I remove the bottle stopper. It is about a 1/2" in dia. Thx. Steve
    New Friend:
Try using a vacuum cleaner to suck the bottle cap otherwise fill the tray with water and when the cap starts floating you can take it out
Posted on Dec 12, 2013
  • Frigidaire Master
  • 19,396 Answers
Unplug machine from power, do not restart it until you get the plastic cap, as you can cause more damage.
Try first using a long stick to reach the object at the end of the drawer, inside the hose, be careful not to hole the hose or brak other parts inside the drawer.
If it does not come out this way, I am afraid you will need to take apart the back , and probably also the top panel.
You need to access the hose starting from the detergent drawer and ending into the pump, once the hose is lose on both sides you blow compressed air inside the hose.
If you do not start the machine the pump cannot be damaged.
If you start the washing machine with the object inside, in the best case it will malfunction because hose is obstructed. In worst case you burn the pump as the hose get obstructed.
If machine is less than one year old this maintainance can be covered with guaranty,
If you need to call in a repairman you can use the number listed at the end of the user manual.
Regards
Posted on Aug 31, 2008
Noisey drum
Hi, What machine have you got? Some machines you can remove the lifters to get inside the drum, or you maybe able to remove the sump hose, I normally take out the heating element and use a magnetic tool to get foreign objects out, be warned though sometimes you may not be able to refit the heater because the seal would have been compressed, and therfore would have to buy a new one, I recommend getting the top removed as using the machine with it in can result in a lot of damage.
Mar 11, 2013 | Washing Machines
I have a whirlpool duet washer that when it is started the water runs out of the soap dispenser and when draining there is a grinding whine as the barrel spins. Does anyone have a solution for this?
Remove the soap dispenser check drain hole for foreign object. I've seen socks, toys, and those new soap pod casings cause the same symptom. Try to spin your basket buy hand. It should spin freely and coast to a stop with no noise. If you hear scraping or if it comes to a sudden stop, there is likey a sock or the like between the basket and tub. Use a flashlight to locate by shining it at the holes in basket. If it's there you will likely see it. Try to drag it out of there with straightened hanger or perhaps it's close enough to grab with needlenose pliers. Good Luck.
Jan 06, 2013 | Whirlpool Washing Machines
We have the single handle Pegasus 190 571 Brushed Nickel bathroom faucet. The soap dispenser got knocked and broke off and I cannot find a replacement for it.
The booklet that comes with that unit has the following part numbers: nut set (A66D111); soap dispenser sleeve (A665597); soap pump (A605230); soap dispenser nozzle (A66596). Those are all the parts (less plastic tube and soap reservoir bottle) for the dispenser- you probably only need one (the broken one!).
Jun 17, 2010 | Home
Soap dispenser doesn't pick up soap
Make sure the clear tube is inserted into the pump head properly.Make sure the tube is not kinked. try filling the bottle full of water and try pumping the water out first. Sometimes the dispenser gets an air lock and takes a bit of continuous pumping to get it to work
Feb 24, 2010 | Price Pfister Marielle Kitchen Faucet with...
Water is coming out of the soap dispenser, what do
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this
Oct 05, 2009 | Kenmore HE2 Plus Front Load Washer
Inoperable Soap Dispenser
if the balls fell out you need a new head,sorry.
Jun 20, 2009 | Price Pfister Marielle Kitchen Faucet with...
KOLHER Soap dispenser won't dispence soap.
Pull the dispenser out. Put it in semi hot water foe a few minutes to clean it. Then put the pickup tube in a glass of water and pump it untill water comes out. They get clogged with soap after so long.
Good Luck
Kurt
Mar 01, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Dropped a plastic piece into soap dispenser
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Quiet Partnet II Rinsing solution compartment
WITH REGARDS TO YOUR MACHINE NOT TAKING THE FULL BOTTLE OF RINSE AID YOU WILL HAVE TO TRY AND CLEAN OUT THE SOAP POWDER THAT WAS PUT IN THERE YOU MIGHT NEED TO STRIP THE DISPENSER DOWN IF YOU CAN NOT CLEAN IT FROM THE TOP.
IF ALL FAILS IT WILL BE BNEST TO CHANGE THE DISPENSER :-(
GOODLUCK.
MOHAMED
Jun 01, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Frigidaire ATF6000ES Front Load Washer Logo
75 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
