Question about Sewing Machines
Threading Diagram I am one of the many it seems that can not figure out how to thread this machine either. Would you be so kind as to send me the diagram as well? I would be very grateful. Susan susan@eargallerymusic.com
  • 323 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Sep 03, 2008
Threading a nelco 5102
Machines generally thread similarly. Just be sure to ALWAYS RAISE the presser foot when threading the top thread.
Nelco JA 38 Sewing Machine Threading Diagram
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Jul 29, 2017 | Sewing Machines
Viking Huskylock 560 ED threading diagram
Viking 560 ED Huskylock Handbook
Threading Serger this may be helpful even if it is not the same model. The sequence of threading loopers is VERY important. If you thread them out of order, be prepared to be frustrated beyond belief!!! Something else (I don't think she mentioned) is to ALWAYS RAISE the presser foot when threading your machine. This is true for sergers AND sewing machines!
How to thread Serger
Nov 17, 2016 | Sewing Machines
How to thread this machine
New Home Model 532 Sewing Machine Threading Diagram
or search the internet for:
New Home + (Model #) + threading diagram
Hint: Always Raise the Presser Foot when threading the upper thread. This insures the thread will seat properly in the tension disk.
Jul 20, 2016 | Sewing Machines
II HAVE AN OLD MONTGOMERY WARD MACHINE I have tried to find a machine that looks like this one online but have not so far. I need instruction on threading it on top of the machine i think ts is a ten
I have been repairing sewing machines for a couple of years, and it seems to me that if it is old and not a Singer then it is a White. Research vintage/old White sewing machine on line and you can probably find a threading diagram.
Good luck,
Bob
May 31, 2017 | Montgomery Ward Sewing Machines
I need a diagram of how to thread my overlocker - Bernina Funlock 006D
contact bernina and see if they have a diagram for threading
Mar 19, 2013 | Sewing Machines
Need threading diagram for model #1766
Go sewusa.com for a free threading diagram.
Feb 20, 2010 | White Sewing 1766 Mechanical Sewing...
Brother serger thread
The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
sewman7
Jun 17, 2008 | Brother Lay-In Thread Serger Mechanical...
Sewing Machines Logo
190 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
