Question about Frigidaire CWS3600AS Top Load Washer
Washer machine cut off
My washer machine will not come on. it cut off right in the middle of washing and has never came back on what can i do?
  • 943 Answers
Check the lid switch they do go check power at outlet 110 volts plug in a lamp in that outlet to see if the voltage is there thanks the appliance doc
Posted on Sep 13, 2008
Samsung front loader washing machine power cut out mid load
If by turning off the power you mean you hit the power button .... try unplugging the machine for about 15 seconds and then plug it back in ... this may reset the machine. If not you may want to call Samsung ...
http://www.samsung.com/au/info/contactus.html Hope this helps!
Nov 25, 2013 | Samsung WF337AA Front Load Washer
Washing clothes and machine cut off..no lights and can't open door.
First check your circuit breaker in your circuit panel box to see if it is thrown. It will not be in the ON position if thrown. It will be approximately in the middle. If thrown, turn to off and then turn it on. If it throws again, you have an electrical problem either with your washer or the circuit.
Jun 19, 2011 | Maytag MAH8700A Front Load Washer
Error code f 35 on whirlpool duet washer
Just tilt the washer back and prop it up with some wood blocks. Three screws are right on the front at the very bottom. Use a 9/32 socket to remove them. The front cover slides right off. The drain trapclean out is right in the middle. Turn the large white knob counter-clockwise to remove it and clean.
Thank you !!
Aug 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine codes and how to check different parts
Thank you !!
Aug 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Frigidaire Washer will not spin and has started cutting off in the middle of washing.
The computer sensor on the door is bad. That's what the repairman said when that happened to my washer. The washer wasn't sensing that the door was closed, even though it was. Therefore it wouldn't go into the spin cycle.
Aug 14, 2009 | Frigidaire ATF6000ES Front Load Washer
How to replace lid switch assembly #3949247 for a Whirlpool Washe
we just bypass them,unless your going to stick your hand in there during spin cycle,-unplug washer,remove the 2 head screws 1 on each side of the head,flip the head up,you will see the lid switch jack in the middle of the top of washer, unplug it,cut the 2 outside wires and wire nut them together,plug back in,put the head back,plug in washer and your done,this way it cost you nothing to fix,the other way would be around $40,let me know how you do-mike
Apr 20, 2009 | Whirlpool LSR6232J Top Load Washer
Not spinning after wash cycle
remove the 2 console screws one on each side of front or they may be on the back of console,flip it up and you will see the lid switch jack on the washer in the middle,unplugon the washer side you want two cut the 2 outside and wire nut them together,this will by pass the lid switch,plug back in,put console back and you should be good to go-mike
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Quietline dryer does not work!
If you're gonna get a new washing machine, its best not to consider a washer dryer as they tend to have a lower and shorter life span. Best thing is, if you really have to get a washer dryer, or a washing machine, try bosch. They really are the best
Oct 09, 2007 | QuietLine WD-9900 Front Load Washer /...
Frigidaire CWS3600AS Top Load Washer Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
