Question about Neff W4380X1 Front Load Washer
Neff W4380X1 LED 01 appearing
Trying to run a wash programme, the machine will run for about 10 minutes, then beeps continuously, and there's a number 1 in the LED. Machine won't actually allow you to spin, or do anything. Haven't a clue what this means, as the instruction manual  has been lost long time ago (previous owners)  Any help and/or a copy of the instruction manual would be greatly appreciated.
  • akhil_sharma Sep 06, 2008
    Trying to run a wash programme, the machine will not run and after about 1 minute, it automatically goes to prewash mode, and there's a number 15 in the LED. Machine won't actually allow you to wash, rinse, spin, or do anything. Haven't a clue what this means, as the instruction manual has not been provided by the landlord. Any help and/or a copy of the instruction manual would be greatly appreciated.
  • keith gordon Oct 08, 2008
    I have exactly the same problem. Recently refitted utility room, when Machine was reconnected it now will fill and do one was but will not rinse. It displays error 01.
    Any assistance or advice gratefully recieved.
This is a water supply fault. Check that the hoses at the back of the machine are not squashed and check to see if there is water getting into the machine
Posted on Feb 11, 2011
E - 01, NEFF WASHER DRYER
there is to your right an bottom of washer a small door open it an you should see a small switch that you can take a small long screwdrive pess it down an door will unlock ok
Oct 20, 2017 | Neff V4380X0 Front Load Washer / Dryer
Neff washing machine - barrel doesnt spin
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Jun 23, 2009 | Neff W4380X1 Front Load Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff W4380X is showing error code 01
error code 1 is usually not heating it will progress through rinse as heat is not called for, when moves to heat stage will stop at that point inexpensive part to replace.
Oct 08, 2008 | Neff W4380X1 Front Load Washer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Power cuts when 'on' switch is released!
Easy, remove the top the switch unclips and slides out from the front panel, you cannot sucesfully repair these switches so a replacement should be obtained
Dec 31, 2007 | Neff W4380X1 Front Load Washer
Detergent & Conditioner Drawer
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Oct 30, 2007 | Neff W4380X1 Front Load Washer
Neff w4380x1gb
We have had the same problem - £208 for a new power board - IT DID NOT FIX THE PROBLEM
Jun 01, 2007 | Neff W4380X1 Front Load Washer
Neff W4380X1 Front Load Washer Logo
312 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
