Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
Regulator freezing up
When I replaced the propane tank, the regulator began freezing up. I checked for leaks with no leaks detected. Disconnected and reconnect the tank and the problem still remains. The burners are lighting and have the correct color flame although there appears to be more aiy in the burners than before. What is the problem? Can I continue to use the grill?
  • vito23 Jan 10, 2009
    brand new kenmore 3 burner grille with the side burner...sears assembled it, i got it home, hooked up a newly filled blue rhino tank, and all the burners lit, but the regulator iced up within minutes..also, ice formed on where the hose attaches to the burners...i am afrid the whole thing is gonna blow up on me. I checked for leaks with soapy water on all fittings and there are no leaks...
    President:
  • 1,263 Answers
Did you replace the regulater with a manufatures replacement for you grill or did you use an after market one? the reason i ask is because propane is very cold in liquid form and if your regulater allows more of the liguid to go to your burners than it should the moisture in the air will contact the outside of your regulater and freeze up on it. excessive propane would not change the color of the flame, however the i would check the burners to make sure that there are no blocked holes this would cause this to happen as well you are still safe to use the grill but cleaning the burners is a good idea. also there is a rating on the regulater make sure it matches the old one you replaced it with........good luck
Posted on Aug 31, 2008
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Jan 26, 2014 | All-Pro Propane Garage Shop Heaters - All...
My propane storage compartment smells like propane and my regulator freezes up but there are no apperent leaks
You store propane in a compartment? Propane MUST have ventilation or it will collect in there and explode. If you smell propane the re there IS a leak, turn off your tank and do not close that compartment up.
Jun 16, 2011 | Heating & Cooling
My LPG regulator ices over and freezes in my Toyota Landcruiser dual fuel 4x4.
I would have it checked for a leak, when LPG leaks it will cause freezing of the valve. LPG under pressure gets extremely cold when it is released. I see this all the time around shut off valves on propane tanks. I am not a Toyota Mechanic so I can't say for sure, but it sounds like the regualtor has a small leak in it. Some fork trucks use these regulators and I have seen them freeze up just from being used as gas passes thru the regulator. does this freeze up when you are using LPG or does it freeze up all the time. If it is freezing while not being used, I would definatly have it checked for a leak.
Nov 15, 2010 | Toyota Land Cruiser Cars & Trucks
I have a Char-Broil Grill. My regulator started frosing over or turning white like a freon can would and so I changed the regulator and the new one is doing the same thing. I just replace the bottle...
This is normal under certain temperature and humidity conditions. The gas is expanding as it goes through the regulator and this causes cooling - that much is always the case. If you have had cool weather for a while, then the propane will be cold to start with. The expanding gas will cool the regulator to a temperature significantly cooler than the temperature of the gas in the tank. If it's humid outside, then condensation is going to form and if the regulator is below 32 F, you will get frost. Nothing to worry about, it has no impact on the performance of the regulator. This effect will diminish when the temperature of the propane goes up (after a warm day) and as the level of propane in the tank is reduced (so the pressure drop across the regulator will be less.)
Aug 17, 2010 | Garden
Propane was leaking between tank and regulator on my BBQ. Replaced with three new regulators and two new propane tanks but still get strong hissing from vent hole and strong smell of propane when I open...
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Jul 29, 2010 | Char-Broil Grilling
Weber Spirit one month old...went out, changed tank, won't light
The regulator that comes with Weber grills shuts the gas flow off if it detects the slightest leak. Disconnect the tank an reconnect. Check connections with soapy water for any leaks. Another problem, though uncommon for a new grill is a defective regulator. You have a 1 year warrenty on your grill so contact Weber if you continue to have problems.
Apr 26, 2010 | Weber Spirit? E-310 Propane Grill
The regulator is freezing up. I just replaced the tubing, regulator, and hose with new oarts. Still freezing up
Are you opening your propane tank valve all the way? This will cause what you are seeing and there is an easy fix - when you open your propane bottle valve, only open it one to two turns and your regulator shouldn't freeze up.
Oct 07, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
The regulator freezes on my three burner Barbeques Galore Grill
This can happen when an excessive amount of propane gas is used or when if the tank you are using is not sitting upright, therefore allowing liquid propane to exit the tank through the regulator.
Jul 08, 2008 | Grilling
Gas Grill regulator freeze
yes you need to replace the regulator it sounds as if the vent is plugged.
Hope this helps
Jun 22, 2008 | Grilling
The line & valve on my grill's propane tank freeze up
I suggest cleaning and drying out the line as it sounds like there may be water in it.
Liquid propane could be getting into your regulator as well, make sure your propane tank is upright with the output on the top.
Make sure your regulator vent hole is clean and is facing down toward the ground.
If you are in a very cold or humid climate, you may also want to look into a regulator cover.
Nov 11, 2017 | Kitchen Appliances - Others
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
1,314 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
