Question about Acoustic Research AW-771 Consumer Headphones
Wireless AW771 - 900MHZ Stereo Headphones with Auto Tuning
Wireless aw771 headset will not receive and never has.
  • Anonymous Oct 27, 2008
    Headphones never worked. I thought initially, due to my limited electronic skills, I had not hooked the system up correctly. I then convinced a friend who has alot of experience with sort of thing and he could not get them to work. I then took them back to H G. Gregg a year had passed. therefore, they would not exchange or refund,. I then contacted the manufacturer and they again advised you have had them for more than a year and the only way we can fix them is for you to approve $55.00 repair. I did that and should have them in my hands within 7 to 10 days.
2 Suggested Answers
SOURCE: Lost Manual for Acoustic Research AW771 headphones
Here is the link for the manual
http://www.solidsignal.tv/manuals/AW-771.pdf
Posted on Jun 17, 2009
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
How do you make a call ,using 903+Bluetooth Headphones
To make a call using your 903 you can dial it on your phone and you can proceed that way, or you can do a 2 second press on your headset using voice command.
Good luck from Headsets Direct!
May 01, 2011 | Plantronics Backbeat 903 Bluetooth...
Okia 3110c i cannot receive any files from
blue tooth IC is malfunctioning u will need to replace it. Also check if u can send through bluetooth if u can then u need to dump all items into folders and then check
Oct 13, 2009 | Nokia 3110 Cellular Phone
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Goodmans headphone PRD CD 9007 SRD-S1 1996-I-GB. The service Phone number on the set is un-obtainable. I require to be able to use two sets of headphones from the same TV. Can this be done using the...
You can use a spliter that turns one output into two so you could connect two sets of headphones into the tv, I don't know if two headphones can be used with the same base, which company where you trying to reach`?
Nov 29, 2008 | Televison & Video
SPV M2000 Bluetooth Headset use
go to settings connectivity then bluetooth it should say my devices go there
then turn on your bluetooth headset and click on look for more devices
Oct 18, 2007 | Orange SPV M2000 Pocket PC
Acoustic Research AW-771 Consumer Headphones Logo
116 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
