Question about Bulova Watch
Manual for United Colors of Benetton Chrono by BULOVA Quartz Watch
Hi i just bought on line this watch United Colors of Benetton Chrono by BULOVA Quartz Watch but it did not come with manual..
where i can find that manual..
thanks so much
SOURCE: Opening Bulova Casement
Take it to a local jewelery store and they will do it for about $15. Joe
Posted on Oct 03, 2007
SOURCE: rotary chrono alarm watch 9871
Hi. Just bought an example of this model, complete with manual and Guarantee papers. I would not mind making a copy for you, if you just need the information on how to work yours. By return, any information you have about the watch, like where I can get a replacement stopwatch button, would be helpful. Otherwise, feel free to contact me.
Best regards,
Robert Powell-Jones
Posted on Oct 04, 2008
  • 3 Answers
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
Posted on Jan 05, 2009
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
  • 2501 Answers
SOURCE: I need a manual for a Festina, Chrono Bike, watch
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
Posted on Mar 12, 2010
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Chrono hands
Please make sure that you have replaced your battery properly.I suggest you t reinstall it once again.
Let me know the result
Aug 21, 2008 | Tag Heuer Link Quartz WJ1110.BA0570 Wrist...
I have a bretling colt quartz watch and the hour regester will not reset
Try pulling out the winding crown,then press the chrono pusher.This will advance the chrono hands.Each pusher will advance a different hand.
Aug 13, 2010 | Breitling Colt Quartz 820 Wrist Watch
I have a bulova 18K gold men's wrist watch, which says 3063-5020 AO in a square on the back. Swiss A6 18K. And it is a battery watch, and is still running any idea? of year or price it is very heavy on the...
mcdevito75 here, The movement number tells all, but I would figure the yaer somewhere in the 80"s and value at $250----$350.-- Accutron very collectable watch. Look for a small watch repair shop in your area for more accurate info. Hope this hepls.
Aug 02, 2010 | Accutron Swiss Watch by Bulova 26B44
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
Mar 05, 2010 | Accutron Swiss Watch by Bulova 26B44
Instr. 4 Nat. Geo. wtch w/ Rhonda 5130.D mvemnt #NG761GSSK
http://www.ronda-startech.com/chrono/main.php?x=functions
Turns out Rhonda has a website with specs. and diagrams for all of their movements
guess I shoulda thought of that first. Anyone needing info for a Rhonda movement check
the above link.......
Feb 02, 2009 | Bulova Watch
Flashing numbers in squares
Flashing Squares means battery going dead - time to replace. May take up to 3 months to stop.
Aug 25, 2006 | Accutron Breckenridge Chrono 26B29 Wrist...
Bulova Watch Logo
1,627 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
