Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
Bissell not removing any water from carpet
Worked fine the last time I used it but not it is dispensing water and solution fine but not removing any water at all. Any ideas?
  • 1 more comment
  • Regina Kirk Sep 20, 2008
    The Bissell carpet cleaner will spray but it wont **** up any of the water from the carpet. Any Ideas on what to do?
  • Katiedvm06 Sep 28, 2008
    Turns on, dispenses soap, does not dispense water or clean foor.
  • ckbbuckeye4 Oct 24, 2008
    Our steam cleaner does not spray soap mixture or vacuum up water at this point. It worked great when we first purchased it. Any suggestions?
  • 3 Answers
When you turn the vacuum on check to see if the brush underneath is spinning if not you have to replace the belt
Posted on Feb 17, 2009
There is a washer type of deal that goes between the water container and the vacuum. if it isnt there , ther is no suction.
my kids lost mine-------------
Posted on Dec 02, 2008
Bissell carpet shampooer model 9200-9 that is not dispensing cleaning solution
I had the same problem with my Bissell carpet cleaner. I tried all the recommendations but nothing worked. After reading all the blogs, I discovered that many people had the same problem. Fortunately, I still had the receipt from Costco which they honored and gave me a full refund. I was ready to throw it in the trash.
Oct 06, 2015 | Bissell 2X Proheat 9200 rug cleaner
How can I operate the Bissell PROheat 2X carpet/upholstery cleaner without instructions?
Your solenoid that activates the hand unit is most likely burned up. Bissell 2X machines generally last 4 to 6 uses and a solenoid burns up. This is the only machine that we do not offer repair service for in my store. It is a terribly poor quality design.
BTW, the brushes aren't supposed to turn when the machine is in the upright position.
Sep 18, 2014 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
I have a Bissell ProHeat Turbo. It has only been
i use white vinegar to clear my line.. and it doesn't hurt the carpet.
check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Leaking rusty water
Ensure the black "duckbill" gasket is mounted on the bottom of the dirty water tank. This gasket is removeable, and resembles a duck bill.
When i purchased mine at Target, new - it was missing the gasket, causing loss of suction. Interestingly it worked for a week or 2 then started leaking. Now, with the gasket in place, it works like a charm.
Gasket is about 2 bucks available from Bissell.
Aug 14, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell carpet shampooer wont dispense water
Bad Pump. You pump is where the belt attaches to spin the brushes and also puts water on the floor. Take it to you local Best Buy to be serviced or a local appliance shop which may service it.
Dec 15, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
236 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
