Question about Asko 24 in. D3250 Built-in Dishwasher
Dishwasher won't start. already tried the latch it seems to be ok. early on a technician had to re-program the machine. could this be the same problem?
Bob
    Genius:
  • 1,665 Answers
Posted on Aug 31, 2008
Asko d3250 pump runs continuously
I have a D3450 that was doing the same. Eventually I ascertained that there was a pressure switch that was not functioning properly. On the D3250 it was only accessible from the rear after taking off the lower panel on the back. It was a black part with a red membrane of sorts. I just disconnected its wire connector instead of replacing the part as it was rather expensive. I've been running mine machine at least 2x day for months since with no problems. Good luck! e53c3564-9255-4057-93f1-a616c7ab21ca.jpg
May 27, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
My dishwasher seems to leave a film on my glasses and even the racks and area around the outside of the dishwasher have a film
Try different detergents--some do work better than others. Make sure the water is being heated properly. Good luck!
Jan 25, 2011 | Asko 24 in. D3250 Built-in Dishwasher
I have a D3251 and the door won't close/latch....how do I solve this problem? Thank you
I just had this problem and it seemed to be fairly easy to fix. Some times when you open and close the door interrupting washing cycles, the latch will think it is already latched. Even though it will still close with pressure, it seems like it will pop back out on you. Here's the fix. If you open the door, you will see a white plastic accepting latch that can be flipped back into the fully open direction using a screwdriver. That seemed to do the trick.
Jun 02, 2010 | Asko 24 in. D3250 Built-in Dishwasher
ASko D3250 fully integrated - hotsteam/water swelling joinery
check the area of leak sounds like seals gone on dishwasher see if seal can be put back into groove posistion
Aug 03, 2009 | Asko 24 in. D3250 Built-in Dishwasher
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 25, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Overfill protection tripping
Is there water in the drip pan? My asko developed a leaky inlet solenoid, which would fill the drip pan eventually causing a failure. If the water evaporated, the washer would run. Normally, there should be no water in the drip pan.
May 01, 2007 | Asko 24 in. D3250 Built-in Dishwasher
Asko 24 in. D3250 Built-in Dishwasher Logo
242 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
