Question about HP DeskJet 5550 InkJet Printer
Dead Printer Found printer dead after daughter was using it. Power to printer OK, no paper jams. She is not around to explain what happened to make it quit. Unable to locate fuse or other reason for lack of power. No power at rear of on/off switch...
  • depreuss Sep 01, 2008
    Thanks, Bubbabear64, but the AC adaptor is putting out a solid 30vdc. I popped the front cover housing the switches and found nothing at the rear of the on/off switch. Acts like a blown fuse or open circuit breaker but I can see no signs of either. Toast?
  • depreuss Sep 02, 2008
    Bubbabear64, thanks for your comments. It is always refreshing to get a second opinion before trashing something that looks like it ought to work. Now I'll see if I can find a new printer that can use all the old print cartridges....
  • HP Master
  • 2,794 Answers
Does your printer operate off of an AC adaptor? If it does it can be replaced very easily either through HP or you can find one at an electronic store like Radio Shack. They can test it there for you as well.
Posted on Aug 31, 2008
  • Tim Babcock
    Tim Babcock Sep 01, 2008
    I have had that with deskjets in the past and yes they were toast when that happened. The electronics are pretty simple on them but usually more expensive to replace than to get a new printer.
I cleared the paper jam and hit "OK," but it still says there is a paper jam. I have blown out any bits of paper and dust and replaced the door and it still gives me the error. When I press "OK" the...
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 20, 2010 | HP Photosmart C6180 All-In-One InkJet...
Tip
Printing tips for paper jam
<b>ThePaper Jam</b> Wehave all had this one happen. You are printing merrilyaway when all of a suddenyou hear that distinctive crunch of paper gettingeaten by your printer. Youimmediately cancel the print job, leap from yourdesk and flip open the printer."Ugh," you say as you notice the crinkled edgesof paper wrapped around godknows what. Okay, so you have found the problem,but what do you do? Thebest way to remove a paper jam is to gently pull thepaper in the direction ofthe paper path-with power off, of course. Whateveryou do, don not pull thepaper backwards. You could damage your printer foreverby doing so!
on Mar 31, 2011 | Office Equipment & Supplies
Tip
Paper jam problem
We have all had this one happen. You are printing merrilyaway when all of a sudden you hear that distinctive crunch of paper gettingeaten by your printer. You immediately cancel the print job, leap from yourdesk and flip open the printer. "Ugh," you say as you notice the crinkled edgesof paper wrapped around god knows what. Okay, so you have found the problem,but what do you do?
The best way to remove a paper jam is to gently pull thepaper in the direction of the paper path—with power off, of course. Whateveryou do, don not pull the paper backwards. You could damage your printer foreverby doing so.
on Aug 23, 2010 | Office Equipment & Supplies
Printer reads:'the paper is jammed. Clear the Paper and press ok
Could be a broken or bent sensor inside, it happens when you pull out a paper jam sometimes. You need a shop to check it out, around $80.00 to repair.
Aug 10, 2009 | Canon MP610 Photo All-In-One Printer
Hp6210 says "Paper Jam. Clear Jam and then Press OK". There is no paper stuck in it, nothing visible at all.
Open the rear clean out cover and check for a jam. Or the rear clean out cover could just be off like mine was. I was get out of paper message. So I found a the HP help manual that there was a rear clean out. I reached around back and found that i twas off, I popped it back on and it works just fine now.
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
Yes vintos after long storage problems with the printer heads may arrise.
Thermal changes from being in storage can cause the printer heads to dry up and fail.
DO NOT USE ALCOHOL or other solvents in an attempt to clear the printer heads.
1. Attempt to change ink cartridges , this may clear the issue.
If that fails , you may be forced to change printer heads at that point.
Link to Printer Trouble Shooting. ( generic steps for all printers )
http://www.duxcw.com/digest/Howto/troubleshoot/print/index.html
Thank you for choosing FixYa!
Az. Wizard Division.
Sep 23, 2008 | Canon Office Equipment & Supplies
Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Try shutting the printer completely down & unplug power. then plug power back in and while holding down all buttons on the printer control panel, turn it back on. this should put it into a self diagnostic mode that prints out just about everything the printer can do, including a sample page. Also, be sure all rollers are clean & trays are completely closed before restarting. If the printer works when you do this, you should most liely check all settings in the software package (driver) or perhaps reinstall the drivers. If this is necessary, be sure to download the latest drivers from the Brother website.
Feb 10, 2008 | Brother HL 1440 Laser Printer
Dead Printer
I understand that you are receiving paper jam error.
Please follow the below given instructions to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=90809&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Jan 28, 2008 | HP PSC 2175 All-In-One InkJet Printer
Paper Jam...and no paper is in side
make sure the machine is clean inside and you have the right paper
Jan 01, 2008 | Lexmark X5470 All-In-One InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
Seeker5211
Seeker5211
