Question about Car Audio & Video
My protection light want shut off.
Is there a way i could get my amps protect light to go off without going to a repair shops? If so could you tell me how or send diagram showing how.
  • bigbooty561 Mar 20, 2009
    i have a formula 5175 1200 watt amp with two 12s. the protection light wont go off unless the remote wire is removed and the4 amp wont work without the remote wire...... help!!!
  • Anonymous Mar 29, 2009
    I have the same problem and sent it back to the place I purchased and they say amp is fine but have sent replacement back anyway, it still doesnt work, have tested wiring on another amp and sub and its fine, any one any idea? Stupid prt mode, its a fusion sub and amp
    Problem Solver:
  • 13 Answers
Not if the amp is damaged. An amp that remains in protect mode (after cycling the power) usually has an internal fault and must be repaired.
Posted on Sep 04, 2008
1998 k1500 chevy pickup wiring diagram
Get a wiring diagram off a data base at
local repair shop
.78 amps is 780 milli amps
You should only have about 40 milli-amps tops,
when everything is sleeping
Dec 16, 2012 | Cars & Trucks
Have 2000 Toyota Camry XLE. Check Engine light appears. Code shows P1035 for Oxygen Sensor Bank 1 Sensor 1 being defective. Replaced sensor. Cleared computer code. Let engine idle for 30 minutes before...
What your asking, is how to make a malfunction light
go away from your dash, so you can forget you have a
problem & make no attempt to repair the car
Until you find & resolve active OBD2 Codes that actually set
a MIL or Check Lamp it will keep coming back
Every time you clear a code you have to run a drive cylce in
some cases to start the procees over, as you need those codes
to diagnose the issues
The codes that are there, do not tell you what to replace
Without writing a book here, just study OBD Systems online &
take the car to a repair shop
It is beyond your ability at this time to figure out
Sep 22, 2011 | 2000 Toyota Camry
I need to know which fuse is for my interior lights and my lighter, the diagram shows nothing and there is so many, as well I never got a book with it. Thank you
Go to a local repair shop & have them
print what you need from ALLDATA etc
Data Base-- a good shop should subscribe to
Jun 08, 2011 | 2002 Buick Rendezvous
My visonik v700hc keeps going into protect modeafter listening for a couple minuits then will go green light then back to red after a coupke more any solutions
I suggest checking what ohm load you're presenting to that amp. go to www.the12volt.com and find the subwoofer wiring diagram and choosing the amount of subs you have on it and then the impedence of each one. you're probably sending too low of an ohm load to the amp this would cause it to go into protection quite frequently and eventually stay in protection.
May 30, 2010 | Visonik V700HC Car Audio Amplifier
My amp suddenly stopped working last night. As
You have a bad amplifier section and your unit will need to be repaired by a technician. I would disconnect the speakers to prevent possible damage. In some cases components in line with the transistors will be bad in the amplifier also. There is no way to tell without electrically testing the unit in shop. Estimated repair cost would be in the 60 to 80 dollar range depending on the number of parts that are bad and the labor rate in your area.
May 04, 2010 | Harman Kardon SIGNATURE 2.1 Amplifier
The protect light came on what do i do
Usually that light comes on by over powering the amp and sending it into protect. Usually by just shutting off the amp and turning it back on solves the issue. Some amps even come back on on there own after about 30 secs. If you have turned it off and back on and the problem still persist, try disconnecting the main power, check all the fuses on the amp and then reconnect the main power. If the problem still persist, then it is time to start looking for a repair shop, return for warranty( if applicable) or buy another amp.
Aug 24, 2009 | Rockford Fosgate Car Audio & Video
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
My 1100d directed amp cuts n and out as i play it, and sometimes
most reputable car audio shops can give you (or have thier own) repair techs. is the new amplifier rated down to the same impedence you have your subs wired to?
Any protection lights coming on the face of the amplifier?
It has a lights that come on for Thermal, DC offset, over/under voltage, reverse polarity and short circuit protection.
May be a faulty turn on module.
Get it repaired before more happens internally for a costlier repair.
Dec 17, 2008 | Directed 1100d Car Audio Amplifier
Protection light goes on on Power up
same thing happened to me a while back it is one of the reistors inside the amp, when you took the turn it anything bumped it or it fell it might have broken off, shake it and see if anything inside rattles, if so then you need to take it to a repair shop or some who can solder
Dec 14, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
ZX3-T4D Audio Amp
Normally that means that you have a blown channel in the amp. Sometimes it can be triggered by a bad speaker. dis-connect your speakers and see if it still goes into protect. If it does not go into protect, yu amy only have a bad speaker. Get them checked to see if one is bad and then replace it with a good one. If the amp still goes into protect, you need to have your amp checked by a professional technician to have it repaired.
There is no way to tell just what is bad inside the amp or how much it will cost without having it checked properly. Sometimes these problems can be fixed for as little as $65 and other times it may cost over $200. It just depends on what is found to be the problem.
If I can be of any more help let me know. I have been repairing car and home audio equipment for nearly 18 years and can be very helpful.
Good luck,
Dave
Aug 01, 2008 | Car Audio & Video
Car Audio & Video Logo
582 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
