Question about Xenon Computers & Internet
18" Xenon Monitor/tv/etc.
Are replacement Backlight Modules available
  • 2,794 Answers
I did a google and couldn't find anything even though the word Xenon is used in several products.
I think the reason why they don't have one available could be due to the mercury switches in them or other hazardous material contained in them as well as accessibility issues.
Posted on Aug 31, 2008
Sanyo DP46142 TV comes on for approximately 30 seconds and then screen goes black. Power LED stays on.
Sounds like a backlight problem to me. If you input a signal to the HDMI or Composite input and then it goes black have you tried taking a flashlight to the screen to see if the picture is still there but just dark? That would indicate a backlight issue. That model appears to be an LED edge lit backlight, so if the picture is still there after going black your going to have to trace out the backlight circuit and see whats going on. Usually with LED backlighting if it comes on at all then the LED's are good, its just the driver supply thats failing to keep them on. Some TV's have a small separate board that provides the backlight control, but i suspect with this model its on the power supply board and not the motherboard. Have you checked that board? It could be bad caps on the power supply board, check the voltages to the backlighting when it lights up and then when it goes dark. It could just be some failed capacitors on the power supply causing that voltage rail to drop off.
May 04, 2017 | Sanyo Televison & Video
Backlight on display went dim
If the backlight has failed or a cable is loose you can replace or repair the backlight of the monitor.
replacement parts are available at
www.pchub.com
www.acerparts.com
I suppose the keycombination FN and arrow up or down has no effect?
Aug 03, 2008 | Acer Aspire 5315 Notebook
How to replace a hp2159m backlight
It is not recommended to replace the backlight unless you have a clean room. Doing so may introduce dust into the LCD panel module. The LCD panel module is held together by metal brackets with latches. You'll need to remove the two metal brackets that hold the sandwiched LCD panel modules together. The you will have access to the actual backlight. Older panel technology made it easy to slide out the backlight for replacement. Nowadays, they lock up the CCFL into the LCD panel module making it not really possible to do backlight replacements if you don't want to introduce dust into the system.
May 15, 2014 | ViewSonic VP2000s 20.1" Flat Panel LCD...
1100 ferrari acer power but no screen?
Assuming no BIOS is displayed
  • Memory could be bad
  • Motherboard could be bad
  • Backlight could be bad
  • Inverter could be bad
  • Screen could be bad
Pull the memory modules out and boot the computer if it makes it to BIOS and then beeps at you one or more of the memory modules are bad, replace one at a time if you have more and test until it breaks again then you know which to replace.
To Test the inverter and backlight hook up an external monitor and boot the computer. If it displays correctly on the monitor then you've narrowed it down to a bad screen, inverter or backlight. Backlights don't usually go out.
Remove the monitor and boot the computer. Shine a flashlight on the screen and look for a very faint image of what should be displayed. If you see one I'd start by replacing the inverter. If you don't see one the screen is bad.
If none of this worked then replace the motherboard.
Dec 15, 2012 | Acer Ferrari 1100 Notebook
I think the backlight has failed. I replaced the
It will be the inverter module or the the back light that is the problem, but until you take it apart and examine the parts and do some testing that will be the key in finding the culprit.
Jan 17, 2011 | NEC AccuSync LCD92V (Black) 19 in. Flat...
When I turn on my computer the monitor turns on for about 3-5 seconds and then goes black. The blue light stays on and does not blink. If I turn the monitor off then back on it will again show the screen...
Had same problem, Monitor first turn on, backlight off after couple of minutes, off/on backlight off after few seconds.
Solution cut J503.
Found voltage OVPT (IC501,7) quite low (1.6V) this is the reference value for VSEN the over voltage value. By cutting J503, OVPT becomes 4.5 volt but is not depending anymore on the current through the lamps. Instead of the link J503 I solder 2x 1N4148 diodes which makes the OVPT not go below 2,8 volt. (diodes in series, cathode points to nearest board edge)
Oct 27, 2010 | Samsung SyncMaster 920NW Monitor
Is there any way to mute the ring tone or put the ringtone on vibrate? While in meetings, etc. I want to leave my phone on but the ring silent. I can't seem to find how to do that on the lg xenon.
on the left side of the lg xenon you will see two buttons with two arrows pointing up and down press that and keep pressing it down or it will appear and you can touch and put it on silent
Aug 09, 2009 | Xenon XEN 1510T 15.1" Flat Panel LCD...
HP Pavilion ze2000 Monitor is dim
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Aug 11, 2008 | Computers & Internet
Computor monitor
The backlight or the power-supply or the inverter. Try replacing capacitors in the Power-supply, any of the larger ones. Backlights:
various lengths are available on eBay for about $20
Jan 24, 2008 | Computers & Internet
Computers & Internet Logo
62 people viewed this question
Top Xenon Computers & Internet Experts
David Payne
David Payne
Are you a Xenon Computer and Internet Expert? Answer questions, earn points and help others
