Dvd-265 only one jack on the side of player, but the lead in the picture shows what looks like 3.5 jack on one end and 3 phono's on the other but i cant see this is right
  • pgraham_nbs Aug 31, 2008
    no the manual is only black and white but the pic shows video in on 1 and audio in(left) on 2 and aodio in( Right) on 3 but i have never seen a 3.5 jack that has av and audio all in one
  • pgraham_nbs Sep 04, 2008
    thanks I will try to get one
    Best Pete.
  • 2,794 Answers
Are the phono jacks colored yellow, red, and white?
Posted on Aug 31, 2008
  • Tim Babcock
    Tim Babcock Aug 31, 2008
    What they do is they create a mini jack with three leads on it. One for video, two for audio. Notebook computers and camcorders have that option as well.
    It could be that the video runs one mini jack and the audio uses another mini jack. Then you can get a mini jack to phono for the video and a Y cable with a stereo mini jack on one end and a red and black phono end on the other side for the audio.
How do I get my ps2 to show on screen
Sounds like you have a composite AV cable - at TV end that would be 3 phono leads red/yellow/white. Set the TV audio visual to CMP for composite!
Oct 18, 2014 | Televison & Video
How do i get my TV to play thru the surround sound of the unit ?
If your TV has a headphone mini jack output ....you need a mini jack to double phono lead ....ask at any decent tech shop.
May 11, 2014 | Insignia IS-DVD040924 DVD Player/VCR
I have Radioshack wireless headphones with a 30 foot range. I cannot hook them up to my new Panasonic Viera 42 inch HD T.V. - The "audio outlet" is a square and the headphones only have red and...
hi there.
At present, the square connector is what is called an "Optical" connector.  It's purely digital and transmits digital data via what looks to us like a RED LIGHT.  Your headphones are incompatible. Your heaphones have an analog connection on RCA Phono type connections.  The type you usually get on the back of hifi equipment.
The pannasonics DO have a headphone socket, but it is the small 3.5mm type socket.  a small round hole that looks slightly larger than a pin head.  It normally has a small diagram of a pair of headphones above or below the socket to indicate what it is.
In order to connect your headphones to your set you will need a stereo,male 3.5mm jack to two RCA Phono jacks.
If your current lead on your headphones has "male" ends, the red and white ends should have silver or gold points sticking out.
If your current lead on your headphones has "female" ends, the red and white ends should have silver or gold surrounds with holes in.
With this in mind, if you have male ends you will require a stereo 3.5mm jack to stereo female Rca Phono vice versa so that they basically lock into eachother forming a "Constant chain".
I have tried to explain this as best I can, I hope you've managed to get the idea of what I'm saying.
You will either need this :
http://cgi.ebay.co.uk/1-2m-3-5mm-Stereo-Jack-2-X-RCA-Phono-Plugs-MP3-/270689011629?pt=UK_Computing_CablesConnectors_RL&hash=item3f065287ad
or this :
http://cgi.ebay.co.uk/3-5MM-STEREO-JACK-MALE-2X-RCA-PHONO-FEMALE-ADAPTER-/360300626060?pt=UK_Computing_CablesConnectors_RL&hash=item53e397408c
Sometimes the colours of connectors vary.  Just remember that Red to Red (for right hand side)  and White to White or Black To White  or Black To Black (for left)
Jan 07, 2011 | Audio Players & Recorders
5.1 speakers connected to a dvd player ?
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
Jul 18, 2010 | Logitech X-530 Computer Speakers
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
How to connect loptop pc to Hitachi 42 inch LCD
Sounds to me like an audio 3.5mm jack to L-R phono leads. The single jack connector would need to go into your pc's line-out port on the soundcard and the red and white phono connections on the other end go to either your television or home theatre system.
Mar 14, 2008 | Televison & Video
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Feb 07, 2008 | Audio Players & Recorders
No video, only audio
With the first problem i would check the Scart lead to make sure both ends are pushed all the way in, if the lead is in at an angle that can cause loss of colour or picture, and that none of the pins are bent. Failing that try another Scart lead.
Most DVD players need to have progressive scan enabled in the settings menu, are you using a HDMI lead or Video Composite, (5 phono plugs)? HDMI is the better of the two!
Nov 27, 2007 | Philips DVP-3005 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
