Question about Mag Innovision Innoscan DTS 3060 Flatbed Scanner
Innoscan dts3050 I have a innoscan dts-3050 that I used to use on a computer running windows 95, I have moved it to a computer running windows 98 SE and can not seem to get it to work.
    Master:
  • 409 Answers
1. Uninstall any twain drivers you have in stalled for your scanner. RESTART
2. Install I/O driver "Port IO" from http://www.driverlinx.com/Software_Products/softwareproducts.htm .....RESTART
Port IO driver
3. In stall your twain driver http://www.maginnovision.com/Service_Support/drivers/dts3050.html
RESTART
Twain driver
Posted on Dec 13, 2008
Driver de Memoria PCI Aspire 3050
If you installed windows 7 on the aspire 3050 ..and you do not have the vga driver for the video and the card reader driver ..here is the place to download and run them into computer ..
The drivers are for vista but will work in windows 7 too ..
(in the worse case , just download the drivers..and before installing them ..just click right and select properties and select under compatibility to run in compatibility with windows vista and apply )
I think they will work ..cause there are no known incompatibilities between these drivers and windows 7
Jan 01, 2012 | Acer Aspire 3050-1733 Notebook
I need a driver for the DTS-3060
Here you go.
http://driverscollection.com/?file_id=19502
Jun 12, 2011 | Mag Innovision Innoscan DTS 3060 Flatbed...
French Dictionary CD Rom dated 2000 for Windows 95-98.
Yes, you can. Copy the disc on the hard drive of your computer. Right click on the .exe file, go to compatibility tab, check for Windows 98, Ok. And after that run the install as normal
Feb 17, 2010 | Video Game Consoles & Games
Is the mag innoscan dts 3050 scanner compatable w/ vista
Sir,
Check this link and let me know if it is worked or not
http://www2.driverguide.com/uploads/uploads21/42031.html
thanks good luck
Sep 14, 2009 | Mag Innovision Innoscan DTS 3060 Flatbed...
MAG innoscan DTS-3060 on Windows XP
Give this a go
Port IO driver
3. Install your twain driver http://www.maginnovision.com/Service_Support/drivers/dts3050.html
RESTART
Twain driver
I must admit I have not tested it, but it seems plausable
Dec 13, 2008 | Mag Innovision Innoscan DTS 3060 Flatbed...
DOES THE VERBATIM HARD DRIVE NEED TO BE FORMATED?
Many Verbatim hard drive models with a FireWire interface come “Mac formatted” – pre-formatted for immediate use with Apple Macintosh computers running Mac OS. They are formatted as HFS+, the preferred format when using the drive exclusively with Mac OS computers.
Note: A Mac-formatted drive will not mount on a Windows PC.
If you plan to use a Mac-formatted hard drive only with computers running Mac OS, you can leave it formatted as it comes from the factory. However, if you plan to use your hard drive with computers running Windows, or with both Mac OS and Windows computers, you should reformat your Verbatim hard drive before saving data to it. Generally, for use with both Mac OS and Windows you should format to FAT32, and for use strictly with Windows you should format to NTFS. More information about these two format types is given below.
FAT32 FAT32 is compatible with the following Windows operating systems: Windows 98, Windows 98 SE, Windows Me, Windows 2000, Windows XP, Windows Vista. FAT32 can also be read by Apple Macintosh computers running Mac OS.
Limitations: Maximum file size is limited to 4TB. Furthermore, using the formatting tools included with Windows 2000, Windows XP, and Windows Vista users will not be able to create partition sizes larger than 32GB (though they can access these larger partitions). This limitation does not apply to other supported operating systems. Furthermore, Verbatim provides a FAT32 format utility (see further below for download instructions) that eliminates the 32GB partition limitation.
FAT32 is a good choice if you’ll be using your Verbatim hard drive with older computers running Windows 98, Windows 98 SE, or Windows Me, or if you’ll be using it with both Windows and Mac OS computers.
NTFS NTFS is compatible with the following Windows operating systems: Windows NT, Windows 2000, Windows XP and Windows Vista. NTFS usually results in higher performance than FAT32, and will permit users to create partition sizes larger than 32GB, and file sizes larger than 4TB.
Limitations: NTFS is not compatible with Windows 98, Windows 98 SE, Windows Me, or Apple Macintosh computers running Mac OS.
NTFS is a good choice if you will be using your Verbatim hard drive only with one or more computers running Windows XP, Windows 2000 or Windows Vista. This is also a good choice if you plan to store files larger than 4TB, such as digital video files.
Per: http://www.verbatim.com/downloads/format.cfm
Good Luck
cbinny1
Oct 20, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
SECURITY
Just an idea, but have you tried running the software in Windows 95 or 98 Compatability mode??
Right click on program icon scroll down to propertys CLICK,...
This should open a box with several tabs on the top.... click tab that says COMPATIBILITY and Check the box that say RUN PROGRAM COMPATABLE with windows 95 or Windowns 98.
Click OK and try the program again.
Just a suggestion, but it MIGHT work. Work a try,
Good Luck,
Sep 28, 2008 | Brother SE-270D Computerized Sewing...
Need help upgrading my labtop
You need the windows 98 se installation cd and product key.
Microsoft no longer supports or makes these so your going to have to find one used, from ebay for example:
http://cgi.ebay.com/MICROSOFT-WINDOWS-98-SE-SECOND-EDITION-CD-NEW-with-KEY_W0QQitemZ320231977797QQihZ011QQcategoryZ162QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mar 27, 2008 | CTX Ez Book 700 Notebook
C-150 OLYMPUS DIGITAL CAMERA
By connecting the camera to a computer with the provided USB cable,
images on a card can be transferred to the computer. Some OS's (operating
systems) may need a special setup when connecting to the camera for the
first time. Follow the chart below. For details on the procedures in the chart,
refer to the “Reference Manual” on the CD-ROM and the “Software
Installation Guide” (included in the CD-ROM package).
Identifying the OS
Windows 98/98 SE
(Second Edition)
Windows 2000
Professional/Me/XP
Mac OS 9.0 - 9.1/OS X
*OS 8.6: See below.
Connecting the camera to a computer using the provided USB cable
Installing the USB
driver for Windows 98
Confirming the computer recognizes the camera
Downloading image files
Disconnecting the USB cable
Even if your computer has a USB connector, data transfer may not function correctly if
you are using one of the operating systems listed below or if you have an add-on USB
connector (extension card, etc.).
● Windows 95/NT 4.0
● Windows 98/98 SE upgrade from Windows 95
● Mac OS 8.6 or lower (except Mac OS 8.6 equipped with USB MASS Storage support
1.3.5 installed at the factory)
● Data transfer is not guaranteed on a home-built PC system or PCs with no factory
installed OS.
You can view images using: graphics applications that support the JPEG
file format (Paint Shop Pro, Photoshop, etc.); Internet browsers (Netscape
Communicator, Microsoft Internet Explorer, etc.); CAMEDIA Master
software; or other software. For details on using commercial graphics
applications, refer to their instruction manuals.
Jan 31, 2008 | Olympus Camedia C-150 Digital Camera
Mag Innovision Innoscan DTS 3060 Flatbed Scanner Logo
127 people viewed this question
Top Mag Innovision Office Equipment & Supplies Experts
k24674
Are you a Mag Innovision Office Equipment and Supply Expert? Answer questions, earn points and help others
