Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
Kenmore/Whirlpool 665 has Loc code that won't go away
I had a PF code because I turned off the electricity. I can't get the gas to come on. I just have this Loc code. I've been fiddling for a whole, so also came up with F0 E0.
  • btdodson Aug 31, 2008
    Solved it myself. Thanks. Master Tech -- you were right. I am a
    dumby. The gas was off. But then I had a new problem. And the new guy
    was totally useless. Wish I had been able to talk to you again.
  • Gary Davd
    Gary Davd May 11, 2010
    I dont understand why you keep posting the same question over and over
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: i am getting an E0 F3 code on my oven
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: message on the display is E0-F2-
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Posted on Oct 01, 2010
How can I determine the cause of the error code on my Kenmore Free Standing Electric range, Model # 911.9344190? Error code is PF.
PF stands for power failure. Check the voltage at the wall outlet and make sure the connections are tight at the terminal block...
Dec 31, 2016 | Kenmore Kitchen Ranges
My Kenmore ultra bake stove model 665 75022101 now has a " Loc" code on the screen. The gas range doesn't work. How do I clear this?
Notice the 2 buttons at the top right, "top" and "oven". If the top burners won't initiate, press and hold for at least 5 seconds the "top" button to unlock it. If the oven won't work, press and hold the "oven" button for at least 5 seconds to unlock it. I hope this helps you!
Sep 15, 2015 | Kenmore Kitchen Ranges
We had a power failure and Kenmore stove showed pf and now loc. cannot get burners to turn on and cannot get loc off.
If you have a power failure or a brown out, it sends a very powerful current through the unit. Please keep in mind that these units are not protected against any surges. If you have a display, that means you have power. Unfortunately, the clock/timer contains relays that control the elements, the oven, etc. You will need to replace the clock to get it running again.
Mar 13, 2014 | Kenmore Stove / Oven / Range Bake Element...
Kenmore gas range window showing failure code PF
Fault Codes
Sears/Kenmore Range/Stove/Oven Manufacturers
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built it.RoperWhirlpoolCaloricKelvinatorGibsonD & M103
647
835
911
155106
110
562
665
198174
960417
662
628253587GESpeed QueenMaytagLittonToshibaFedders363
362651925747562484AmanaWCITappanJenn Air 596790791629
Dec 07, 2012 | Kitchen Ranges
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The dryer is flashing PF
PRESS CANCEL PF CODE WILL GO AWAY, SIGN COMES ON WHEN YOU PLUG OFF AND PLUG BACK IN YOU DRYER
Feb 28, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Whirlpool gas dryer doesn't run. error code pf shows on lcd
pf usually means power failure. Try to clear the screen or hit the off button to clear pf and then see if it works.
Nov 16, 2008 | Whirlpool GGQ8831L Gas Dryer
Kenmore Ultra Bake. Gas won't come on
Loc is a child lock
1)press lock/unlock button for 5-10 seconds
2) set the clock
hope it helps
Aug 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
