Question about Dryers
Whirlpool Senseon Dryer Model GGW9868KQ1. Receiving error code E1. According to research I have done, I need to replace the Thermistor (Part Number AP3919451). Is it difficult to replace? How many parts have to be removed to get to the part that needs to be replaced? Should I call a repair person?
  • 1 more comment
  • Sheryl Bahr
    Sheryl Bahr Aug 31, 2008
    I have been having the same problem. I also have the same model dryer. Any help would be great. Thank You.
  • taemery Sep 28, 2008
    Dryer gives E1 code  wont dry cloths, Is this hard to replace this part or worth calling and paying the man to do it ??? or can I save the money. Thanks
  • treswt2 Mar 12, 2009
    I have the same problem with he Mode GEQ9868JQO. Mine still gets very hot but doesn't dry. Have already cleaned out the vents and te filter and still getting the E1 code. Is it the thermister? where is it located and how do I change it myself?
  • 1028 Answers
SOURCE: Calypso Dryer thermistor replace
if e1 is thermistor code remove bottom panel look behind lint screen housing should be a black oval object with 2 wires just behind housing and to the right of the white thermal fuse
Posted on Sep 03, 2008
appldoctom
  • 311 Answers
SOURCE: warm heat..clothes not drying
john there is only one heating element.ither it works or it dosent.when acustomer complains of low heat or long dry times 99out of100 its the venting or the dryer is blocked with lint.remove the dryer from the venting and try a load.if better clean house venting.you .........if not better you should have a great air flow leaving the dryer so if not drying well with venting off.take dryer apart a clean all araes that air is moving,where lint can block that flow.god bless .tom
Posted on Jan 01, 2009
Maytag317
  • 1136 Answers
SOURCE: I have a gas whirpool senseon dryer model number
Hi, If the ignitor glows and then shuts off before you get a flame, then you will need to change the coils on the top of the gas valve. This is the most common problem with the gas dryer not heating consistant. Make sure your venting to the outside is cleaned out. A plugged went causes the coils to go back quicker.
I hope this helps and please let me knw if I can assist you further.
Thanks
Vic
Posted on May 11, 2009
protek480
  • 1723 Answers
SOURCE: whirlpool duet not heating, replaced thermistor
If it just won't heat, it's a thermostat issue (most likely). You can try a different setting and check if it works. There are different thermostats for different settings. Also there is a contact that is operated by the motor to insure that the drum is turning for heat.
Posted on Jul 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Need part number for thermistor for whirlpool Duet
Number 42 mounts on the blower housing right beside the thermal fuse
1ee95b6.jpgThe price is decent less than $20.
This video shows how to replace it:
Posted on Oct 13, 2010
Kenmore dryer error code e1
The E1 code on this dryer indicates that you have an "open" (defective) thermistor (temperature sensor). Replacing this part will likely fix your problem. What is the model number?
Nov 12, 2012 | Dryers
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
What is an E1 problem with the maytag dryer
This must be a Whirlpool-made Maytag dryer and troubleshooting are therefore basically the same. The error code E1 indicates that the thermistor is open or having a very high resistance. Check the wiring connections to the thermistor and make sure it is not shorted or disconnected. You may need to replace the thermistor located on the blower housing behind lower front access panel. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool-made Dryers Thermistor Troubleshooting
Jul 20, 2011 | Maytag PYE2300AY Electric Dryer
I have a whirlpool gold senseon drying system, it seems to get to hot or something and gives me a code of E1, can you tell me what that means and how to fix it?
Hi
Error E1 means thermistor is open. The thermistor is on the top of the blower housing. Remove the bottom panel, locate the thermistor and replace it. It looks like this--
Please post back if you need more information. Hope this helps...
Daniel
Sep 03, 2010 | Whirlpool Dryers
Clothes seem to take longer to dry and I keep getting an E1 error code on my Whirlpool duet dryer. Model #GGW9209LW0. Dryer is about 8 years old. Lint is not an issue.
The error code E1 indicates the control senses an open thermistor either due to a loose connection or a failed thermistor. Check the thermistor connection to the control and replace the thermistor (part number 8577274) if the connections are good and snug fit.
Remove the two screws securing the toe panel to the cabinet then pull the panel down and out. Remove the hex-head screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the lint duct.
Facing the rear of the dryer, the thermistor, usually black, is located on the blower housing to the right of the thermal fuse. Remove the two screws securing it to the blower housing and secure the new thermistor in place.
Connect the wires then reinstall the lint duct and the lint duct bracket. Slide the toe panel up into position to the cabinet and secure it.
Apr 27, 2010 | Whirlpool GGW9200L Gas Dryer
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My whirlpool gas dryer keeps coming up with E1 error code after drying for about 50 min, model ggw9200lwo. Any solutions to what the probelm might be?
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Mar 28, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
ERROR CODE E1 MODLE #GGW9200LW O
E1 error code is for the thermistor, try cleaning off the bottom of the thermistor, (sometimes tacky lint will coat them), if that doesn't help, just replace the thermistor.
Sep 17, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
526 people viewed this question
Top Dryers Experts
