Question about Whirlpool Calypso GVW9959K Top Load Washer
Warer stop on fill up
I start the washer and it when it starts filling up it will fill about 3 gallons of water and stop.
  • 55 Answers
  1. try to recycle the level control hi and low. Try the hot and cold to try and get more water in the unit. JOHN-LA.
Posted on Sep 01, 2008
I have portable Kenmore washer and don't stop warer filling. Pl. advice.
in most cases the fault is in the water level indicator. either the hose has come of it or the indicator is not working have it replaced.
best of luck
Aug 03, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Hiw many gallons of water with 2 rinses does a top
Your washer takes 35 gallons to wash and 35 gallons to rinse. Ask me how I know? Well I work on them but last December my washer (which is the same as yours) developed a problem with the cold water inlet valve. My inlaws and daughter and friends all come by at different times to use paws paws washer. They pass 50 laundry mats to come to my house. Just for fun I told my wife to get a 5 gallon bucket and fill the washer up. It takes 7 buckets to fill the washer up and get it to start washing. Later she decided to run a water hose out to the washer and fill it up. Then my mother in law suggested she put the washer on rinse and fill the tub. That told me I had a timer problem. But luckily I have 2 or 3 washers around the house I can get parts off of. So to recap: 70 gallons of water to wash a full load of clothes is what I guesstamate it took. Did that slow down my inlaws? Nope.
Mar 05, 2010 | GE WHRE5260E Top Load Washer
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Washer not filling
plz dont take this wrong but you say it fills and WONT STOP?? does the unit over flow on the floor?? or you need to let me know because the last part of your question states a diffrent problem..is the hot water valve on?//plz answer my questions and we can go on.
Feb 17, 2008 | Roper RAS8445KQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
61 people viewed this question
Dan Webster
Dan Webster
Sal De
