Most of the NETGEAR devices, except ReadyNAS products and Fully Managed switches, have the following default username and password:
- Username = admin
- Password = password
- For older devices, password = 1234
If you have changed the default password and have forgotten it, you will need to reset the NETGEAR device to factory default settings in order to use the default username and password.
Click here to learn how to reset the NETGEAR device to factory default settings. Please note: restoring a device to its factory default settings will erase any changes you have saved to the device.
Reset and Restore the NETGEAR device to Factory Default Settings
Symptoms:
Forgotten/lost password to log into the NETGEAR device
- Cannot access the NETGEAR device web interface
Click
here for video walk through example of how to reset the WGR614v9 router.
Resolution: If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is
lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see
No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is
admin and the password is either
password or
1234. Try these before resetting the router.)
- Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
- Release the button.
- Wait for the router to reboot.
- Log in with the default password.
If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
- Unplug the router's power.
- Press and hold the reset button. While the button is held down, reconnect router's power.
- Continue to hold the reset button for 20 seconds after reconnecting the power.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See
Updating Router Firmware That Uses a Manager Port.
Here is a small video that shows you how:
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Good luck.
