Question about Sony KP-53HS10 TV
Screen goes black and resets during HD shows
Been there and done that and power cycling does not correct the problem.
    Genius:
  • 1,269 Answers
Does the problem still persist without the Tivo connected? Try to isolate each devices that are plugged in. Try to watch a normal dvd first without the Tvio connected and see if the same problem occurs.
Posted on Aug 31, 2008
My samsung 550 plasma will not show a screen with I turn the tv on, stays black. I have to cycle power at least 3-4 times before the picture will show up. Once it does, it seems to kick in and out of HD....
Unfortunately although Samsung make great screens they do have a big problem with power supplies. The one in mine went 3 times before I replaced the screen. We have a lot of Samsung's at work and we replace 5-10 power supplies per year. If it's under warranty it'll be done at no cost otherwise you're looking at around $250 (Australian) unfortunately.
Oct 27, 2013 | Samsung LN52A550 LCD TV
Have you already tried to power cycle all the devices? Unplug the power cable on all your devices for about 1 hour then plug it back in. Check if that fixes it.
Aug 31, 2008 | Sony KP-53HS10 TV
High Def input search
It sounds like you arent using the correct ports for a HD tv or arent using a HD digital player or HD cable. Still having problem let me know but thats what it looks like to me. Do you have anything plugged into these ports from a HD device? DVD,Digital Recorder, etc?
Sep 11, 2007 | HP PL4245N 42 in. HD-Ready Plasma...
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
Describe your sylvania lc225ssx green screen Problem Screen goes green occasionally. Switching to an HD channel then back usually corrects for a while. Sometimes power-cycle also temp fix.
Whenever I hear "green screen" it is a loose or faulty HD cable(s).
Check your HD connections to make sure they are inserted fully and if there is no change, try an alternate cable.
Jun 17, 2010 | Sylvania LC225SSX LCD TV
My 2001 Mitsubishi Medallion recently stopped recieveing HD channel from my FIOS HDTV Box. When switching from standard channels(they work) to an HD channel, the screen shows scrambled mutltiple images and...
If the TV works in the "Other" modes than I would suspect, that the FIOS HDTV box has developed some fault. When a TV goes to a "Blue Screen" this means that it cannot interpret a proper signal, maybe you need to reset the FIOS, anyway check that out, the TV itself, I do NOT think is faulty, check connections, antenna and to TV as well. Unplug ALL from wall wait 5 mins, and power back up, this often fixes a lot or problems.
R - Restore: Restore default settings E - Environment: Change your environment, remove from media cabinet, try different media, try different equipment (TV, router, hotspot, etc.). P - Power Cycle: Power cycle by unplugging your networking equipment from wall for 2 minutes to reset. A - Access this Knowledge Center for useful articles to resolve issues. I - Install the latest System Software Update. R - Resolved: In most cases these steps can resolve your issue.
Apr 01, 2010 | Televison & Video
Screen goes black after windows XP logo, then no response.
I would suggest checking your hard drive to see whether or not it has a bad sector on it.
Dec 20, 2008 | HP Pavilion zd8000 Notebook
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
Sceptre
It sound like either a power or power connectivity issue. I recommend that you first complete a hard reset on the tv (unplug all power to the unit and accessories for at least two hours, sometimes more. Then plug the unit and accessories back in. If that does not work then I recommend using one of our premium services or searching for a local repair service search button located on this page. Just type in your zip code.
Thanks,
CH
Jul 29, 2008 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Sony KP-53HS10 TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
