Question about Mitsubishi WS-55511 55" Rear Projection Television
Color out of convergence.
Suddenly, while watching one day, the color went out of alignment and worse. Lots of greens, and a arc across the top corner of the screen. I'd guess one of the rear projectors dropped out of alignment or something, but convergence is no help.
  • 6 more comments
  • ScottJon Sep 03, 2008
    I have the same exact problem
    the TV worked fine this morning and this afternoon, the BLUE is out of convergence and I have a blue arc from the top down and another from the bottom up and the convergence fixer on the remote is no help at all
  • amaupin14 Sep 18, 2008
    Mine acted the same way, this afternoon the blue convergence went screwy. I tried to realign the blue using the advanced utility screen but no luck.
  • knmak Oct 06, 2008
    We've the same problem on color out of convergence. I could move the red horizontal line using the remote but not the vertical line on the righ side of the screen.
  • suprasweet Oct 12, 2008
    same color problem. Please help!!
  • Anonymous Nov 04, 2008
    Me too.
    My ws 55511 has big red arc on top of the screen.
    The red color is not lined up with the other two colors.It shift lower about 1 inch creating a ghost image.
  • 2LeftFeet Dec 07, 2008
    Irish, is replacing the convergence IC difficult or expensive? We got a new board a few months ago - right before our warranty expired, so I need to decide whether to try and fix it myself, get it services, or start looking for another one. Thanks!
  • brianschambe Dec 11, 2008
    blue lens misaligned while watching tv. I can move the lens up and down but not left to right.
  • Anonymous Dec 19, 2008
    I have the same problem. I have had the convergence IC replaced twice since owning it. I purchased the TV in Sept 2003 and have had a repair person out 4 times for issues, twice for the IC. Now it's out of warrenty so I'm going to fix it myself. I checked this site for information on parts and the part listed in this solution was mislabled from the "complete part list" provided by this site.
    The correct part number is: STK393-110
    Sharing in hopes this will help others.
  • 927 Answers
Good Day;
Sounds like the CONVERGENCE IC has failed >STK-110 > 267P155010. TV only Uses one.
Good Luck, big IRISH.
Posted on Oct 01, 2008
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Mitsubishi 65611 has color distortion and bowing
the color convergeance is out of alignment. you need to have a STK chip replaced.
Mar 20, 2010 | Toshiba 50H81 50" Rear Projection...
Color on the screen
Convergence is dead.Know how to solders?Replaced 2 convergence ICS and some or all it resistors.Tries websites Tv repair, to repair it ur self.The shop will cost U $300 for parts and labors.
Feb 02, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Will not focus
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 02, 2010 | Hitachi 57F500 57" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Convergence issue
try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 53uwx10b Convergence
The grid (called an overlay) is put in place to fine-tune one of the colors, usually green. Once one color is adjusted perfectly, the other 2 colors are adjusted to match the first color. For example, if the convergence data is completely erased, the tech will set up the overlay and align the green using to the overlay, and then align the red to the green and then the blue to the green. If the alignment is being done after replacing the convergence IC's because one or 2 colors are slightly off in the corners, the green is usually very close to perfect and the use of the overlay is not absolutely necessary. It is pretty easy to align one color using the outer edges of the screen itself. If you do need the overlay it can be purchased from any Hitachi parts distributor such as Herman Panson, Fox or Union Electronics.
Mar 31, 2008 | Televison & Video
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Nov 10, 2007 | Samsung PCL6215R 62" Rear Projection...
Convergence problem or??
Yes it has power supply and convergence problem let me know if you need help with part # s or how to fix it
Jun 23, 2007 | Samsung PCN5425R 54" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
175 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
