Question about GE Heating & Cooling
I have a new zoneline air condititoner just instaled two days ago and when it is on stop it still runs when the timpture gets warm and it stops and runs i thouth when its on the stop it should stay stopped
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Check the knob to see if its on right,,
Posted on Sep 01, 2008
Lennox 10hpb
change run capacitor on fan. or bad fan motor
Jul 06, 2014 | GE Zoneline AZ38H12DAD Split System Air...
1998 chevy vortec v8 stops accelerating at 3000 rpm when engine at operating temp. problem is worse in warm weather. it will accelerate below 1/4 throttle then when you get in the throttle it just stops....
Have you checked all your vacuum lines. One may have rotted and has a hole sucking in more air then needed messing up the air fuel mixture. Take a can of carburetor cleaner and while the engine is running spray short bursts around the carb and theintake manifold and where any little black hose lines are hooked up.If the engine revs up in rpms then it has an intake leak sucking in air where its not supose too.
This will cause power loss. Also check your air filter to make sure it is not plugged up. Ihope this helps, The Raz
Apr 15, 2010 | 1998 Chevrolet K1500
1998 chevrolet tracker 1.6 16v automatic trans. engine starts but some times later (twice a day) it stops but runs imediately. few days ago I installed new air filter (the old one was very durty). what is...
the automatic trans has a torque lock kind of another gear...hard to explain but if it stalls when stopping then the torque lock solonoid is probably sticking.
Jan 15, 2010 | 1998 Chevrolet Tracker
Fridge/freezer running, but not blowing cold air
sounds like compressor has failed remove the fridge and put your hand on the black unit at the back (compressor) it should be quite warm if running if not its not starting compressor are at there most stress when starting up and if failing this defrost may have killed it completely
Nov 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Ge zoneline az55ho7d when i tunr on it comes on fine, but after 10 minutes the fan in back side stop running and front fan keep running so throw only air no cold air. so what is wrong . is it motor for the...
Could be lack of service. The unit depends on a clean evaporator and condenser coil. The "other" motor you hear is the compressor starting or stopping probably due to either a high pressure or low pressure switch, or thermal cut-out.
Oct 25, 2009 | GE Zoneline AZ55H07D Air Conditioner
Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
Sep 14, 2009 | 2001 Yamaha TW 200
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Fan stopped working on a 2001 Buick Regal
Bad blower resistor. Under dash behind blower motor.
Dec 08, 2008 | 2001 Buick Regal
Zoneline Airconditioning - Winterizing and drain line
Yes this will recycle the room and can be cover outside if it is not a heat pump and will use elec heat strips to heat. As long as it is tilled toward the back the water will run out the back without a drain kit there should also be a drain hole in the bottom.
Oct 06, 2008 | GE Heating & Cooling
Problem with GE Zoneline 5200 model
Heat pumps have saftey circuits that prevent liquid flooding of the compressor. Inadequate airflow across the evaporator in cooling can trip this circuit. Have your package unit serviced with particular attention to cleaning the evaporator coil and be sure your filters are clean and changed frequently in the summer months. Hope this helps GL!
Jun 07, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
48 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
