Question about Toshiba Satellite A105 Notebook
How to change hard drive in Toshiba Satellite Notebook
I have a 92 GB hard drive and i would like to change to a 200 GB hard drive.
  • Toshiba Master
  • 2,794 Answers
Underneath the notbook should be a compartment to access the drive. It should be held be a couple of screws. Make sure the power is out before removing the drive. Look for one that has the same interface as you are replacing. It could drain the battery life of your notebook a little fast but if you already have a 92 gb and your doubling the size of it, it will be a slight drain to it.
Posted on Aug 31, 2008
How much GB does the toshiba satellite have?
Here is the specifications of the Toshiba Satellite A65-S126
  • Built-in Devices Wireless LAN antenna , Stereo speakers
  • Width 13.5 in
  • Depth 11.1 in
  • Height 2.1 in
  • Weight 7.7 lbs
  • Localization United States
  • Notebook type Desktop replacement (7.5 + lbs.)
  • Wireless capabilities IEEE 802.11g , IEEE 802.11b
  • Processor
  • Processor Intel Celeron 2.8 GHz
  • Data Bus Speed 400.0 MHz
  • Chipset Type ATI Mobility Radeon 7000 IGP
  • Cache Memory
  • Type L2 cache
  • Installed Size 128.0 KB
  • RAM
  • Installed Size 256.0 MB / 1.25 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory Specification Compliance PC2700
  • Form Factor SO DIMM 200-pin
  • Configuration Features Provided memory is soldered
  • Storage Controller
  • Storage controller type IDE
  • Storage
  • Floppy Drive None
  • Hard Drive 60.0 GB - 4200.0 rpm
  • Hard drive type Portable
  • Optical Storage (2nd)
  • 2nd optical storage type None
  • Optical Storage
  • Type CD-RW / DVD-ROM combo
  • Read Speed 24x (CD) / 8x (DVD)
  • Write Speed 16x
  • Rewrite Speed 4x
  • Display
  • Display Type 15.0 in TFT active matrix
  • Max Resolution 1024 x 768 ( XGA )
  • Widescreen Display No
  • Color Support 24-bit (16.7 million colors)
  • Video
  • Graphics Processor / Vendor ATI Mobility Radeon 7000 IGP Shared video memory (UMA)
  • Audio
  • Audio Output Sound card
  • Audio Codec Realtek ALC250
  • Compliant Standards DirectMusic , DirectSound , DirectSound3D
  • Audio Input None
  • Input Device(s)
  • Input device type Keyboard , Touchpad
  • Telecom
  • Modem Fax / modem
  • Max Transfer Rate 56.0 Kbps
  • Protocols & Specifications ITU V.92
  • Networking
  • Networking Network adapter
  • Wireless LAN Supported Yes
  • Data Link Protocol Ethernet , Fast Ethernet , IEEE 802.11g , IEEE 802.11b
  • Compliant Standards IEEE 802.11b , IEEE 802.11g
  • Expansion / Connectivity
  • Expansion Slot(s) 1.0 (total) / 1.0 (free) x PC Card - SO DIMM 200-pin , 1.0 (total) / 1.0 (free) x Memory - Type II
  • Interfaces 1.0 x Headphones - Ethernet 10Base-T/100Base-TX - 25 pin D-Sub (DB-25) , 1.0 x Microphone - IEEE 1284 (EPP/ECP) - 15 pin HD D-Sub (HD-15) , 1.0 x Parallel - Output - RJ-11 , 1.0 x Network - Phone line - Mini-phone 3.5 mm , 1.0 x Display / video - S-video output - Mini-phone stereo 3.5 mm , 1.0 x Modem - Input - RJ-45 , 1.0 x Display / video - VGA - 4 pin USB Type A , 3.0 x Hi-Speed USB
  • Miscellaneous
  • Features Power-on password , Hard drive password , Security lock slot (cable lock sold separately)
  • Compliant Standards ACPI , Plug and Play
  • Power
  • Power Device External
  • Voltage Required AC 120/230 V ( 50/60 Hz )
  • Power Provided 90.0 Watt
  • Battery
  • Technology Lithium ion
  • Installed Qty 1.0 / 2.0 (max)
  • Capacity 4300.0 mAh
  • Operating System / Software
  • OS Provided Microsoft Windows XP Home Edition
  • Software AOL , Drivers & Utilities , ArcSoft ShowBiz DVD , Norton Antivirus 2004 (3 months subscription) , Toshiba Custom Utilities , Microsoft Office OneNote 2003 , Microsoft Works , AT&T WorldNet Service , Toshiba Touch and Launch , InterVideo WinDVD 4 , Toshiba Notebook Maximizer , Toshiba Speech System , Toshiba ConfigFree , Adobe Acrobat Reader
Sep 13, 2011 | Toshiba Satellite A65-S126 Notebook
What is the largest hard drive supported by toshiba p25 s507
The specs say that you have a 60Gb. hard drive. If the unit is less than 2 years old, you should be able to install a 200-300 GB. hard drive without any issues. The older laptops have a 137 GB. limit on hard drive partition space. You still can put a larger capacity drive, but you will have to partition the drive into c: 137GB, then the second partition can be any size.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Toshiba Satellite P25-S507 Notebook
Toshiba P305-S8842 does not see the 2nd HDD. This notebook has 2 200 GB hard drives and it used to see them both. I haven't changed anything on the system.
The first thing to do is check that they are both registered in the BIOS. If they are there is a hardware problem and either C or D needs fixing. I suspect that the BIOS has left it out.
Dec 31, 2010 | Toshiba Satellite P305-S8842 Notebook
Hello. i have the toshiba satellite a200-28n and would like to replace the harddisks at 5400 to 7200 rpm.the types of disk are two mk2046gsx 200 gb each one.what harddisk can i choose for...
The maximum size hard disk you can install in your Toshiba depends upon the BIOS. The BIOS can support a hard disk up to a certain capacity. Check the specification of your model Toshiba to see the maximum hard drive it can support.
An alternative -
You can use an external USB hard drive and connect it to your Toshiba and not be restricted by the BIOS. You can use USB hard drive 500 Mb to more than 1 Tb.
The other advantage of using an external USB hard drive is you do not need to install Windows, the device drivers and your programs on the new hard drive.
Jun 11, 2010 | Toshiba Satellite A135-S2386 Notebook...
How to Replace hard drive for Toshiba Satellite L305-S5875
This useful link will help you...
http://www.bixnet.com/toshiba2.html
Jun 24, 2009 | Toshiba Satellite L305-S5875 Notebook
Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
Mar 01, 2009 | Toshiba Satellite M45-S359: M45-S359...
Hard drives!
your harddrive is standard 30 gb on ide connection and u can ad a new hard drive on your notebook up to 250 gb ide but u will have to format the system brandnew
Jan 01, 2009 | Toshiba Satellite A15-S127 Notebook
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hard drive
I think as bigger drive as ya can afford say up to 80GB.. would be OK.. just make sure that the new drive is same type as old and ya be all good.
Jul 28, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
275 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
