Home | Philips | DVDR3455/37 DVD Recorder / HDD Recorder | DVD Door &qu...
Philips DVDR3455/37 DVD Recorder / HDD Recorder
Problem for Philips DVDR3455/37 DVD Recorder / HDD Recorder
DVD Door "Blocked"
By DVDDaddy66 on Aug 31, 2008
My DVDR3455/37 DVD door will not open, says "Blocked" and is not, opened cover and DVD wont drop down to open door.. trying to find a replacement drive ASA 9332.
Best Solution
posted on Dec 01, 2008
Very Helpful)
tlewis_ga
Rank: Apprentice
Rating: 100%, 4 votes
Unplug the dvd from power and all connections and flip it over. You will see a slot that is underneath the dvd drive and is parallell to the front of the unit. You will see a white piece in the slot. You can use a small flat blade screwdriver or toothpick or whatever to slide the piece manually to the side and that will open the door.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on Oct 06, 2008
Very Helpful)
owensheehan
Rank: Apprentice
Rating: 100%, 5 votes
If you look at the cover of the DVD drive itself, you will see a white wheel. This wheel has 2 magnetic washers in it. Once you have the cover with the wheel on it removed, unclip the two halves of the wheel remove one of the magnetic washers then reassemble everything as it was before (Minus one magnetic washer) and the drive should work perfectly. I have had three of these recorders all of the developed this problem, the first 2 were in warranty so I got them replaced, the third is one of those replacements and broke after the warranty so I fixed it myself (after MF services in cork said it was "Uneconomical to repair" and they said it needed a new hard drive, when the hard drive is in perfect working order!) It looks like the two magnets are too strong and overtime something in the drive wears down and causes this malfunction!
Hope this helps, and hopefully you haven't already bought a replacement!
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #3
posted on Aug 31, 2008
Helpful)
Bubbabear64
Rank: Wiz
Rating: 85%, 2108 votes
Unplug the unit, wait 30 seconds, then plug it back in. See if it resets itself.
Was this helpful?
Yes
No
Popular Solutions for Philips DVDR3455/37 DVD
Questions and Unsolved Problems for Philips DVDR3455/37 DVD
Do you recommend Philips DVDR3455/37 DVD Recorder / HDD Recorder?
Answer
Answer
I have HD writer AE when I try to burn a dvd from my panasonic movie cam I get the message Disc not... (More)
Answer
I bought a dvd from America and now find that it is the wrong area or zone code it is 1 for the USA... (More)
Answer
For any discs i inserted to the player, it said the disc is not supported.... what can i do now...... (More)
Answer
will not load dvds will say no disk . will play cds music sound is good fm radioeverything works no... (More)
Answer
I have DvD R5500HDMI I have alittel proplem with the conection could you please explain to me which... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips DVDR3455/37 DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
