The only solution is flashing the phone. There is no application or tools to remove the virus from phone memory.
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
First ,back up all your files and then restore the unit into factory default,you need also to reformat external memory to be able to clear all viruses..... one more prior to download a file into your phone scan first...good luck...
I have seen this kind of problems with the Nokia 5130, I flashed the Nokia 5130 by taking it to Mobile Service Center. Now it's working fine, everything is working as expected! So please flash it by taking to any Mobile Service Center.
The problem might be the phone's internal memory is full or the system is corrupted.
The only way to fix this is by re-programming or re-formatting using JAF box or any equivalent special gadget and software in repairing phones.
Possible also that your MMC is corrupted, so you can also try to start your phone without MMC, if that is the case, scan and reformat your MMC or better yet replace the MMC.
Reasons for this situation and errors are, possible virus infections, misuse of phone, using the phone when it is being charged, calling when it is charged, dropping the phone, short circuting etc. So a visit to a technician would be more ideal.
Hope this helps.Thank you for using Fixya.
please follow these steps to formatt your mobile phone(nokia 5130) CODE 1: --->>*#7370#
CODE 2: --->> STEP: 1. Switch off your Nokia Mobile, STEP: 2. Press------> Call button, press-> 3, press------> * STEP: 3. Now Switch on your Mobile Wait for few seconds until a ‘formatting’ word appeared on the mobile screen and then release the buttons. when you do formatting you will lose all your details.please make a back up and then do formatting thanx
First: better use kasperaskey anti virus. If your desktop pc or laptop has antivirus, have your pc scan your fon memory through bluetooth, or usb cable
OR: If you have Virus On mobile 1 - remove memory card. 2 - dial *#7780# or *#7073* 3 - It format your Phone 4 - Format memory card. and enjoyyyyyyyyyyyyyyyyyyyyyy,
or
FORMATTING PHONE
Hello, Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone. Read and learn more about flashing and how to flash a phone on this link.
all you need is a full reformat to take away the virus, try to remove the sim card and the memory card first before you open your cellphone, then when you open it, try to type *#7370# or *#7780#, if it not work try to go to Menu / Setting / Phone Setting / Restore factory setting.
If it ask for security code, type 1234 or 12345 ( this is the default code, unless you change your code)
