Question about Zyxel Prestige 841 (91-004-226010) Modem
Problems setting up
I now have ethernet connection with my Zyxel p600 but cannot configure my wireless connection. I follow the instructions of the installation CD until it says that it cannot detect a network adaper!! What can I do?
Gsidi64.dll usb driver
Posted on Sep 20, 2008
I have EarthLink Internet is a zyxel p-600 can I connect a wireless router? And if yes what kind should I buy or can it be any wireless router?
If I read this correctly the Zyxel P600 is a wireless device? Take a look at this, is this your device: https://www.magnet.ie/wp-content/uploads/2012/01/ZYXEL-install-and-wireless-set-up.pdf OR HERE: http://www.zyxel.com/products_services/p_660h_series.shtml?t=p You can add a second wireless device, if you want, by using a port on the P600, is that what you are asking? Depending on what you want to connect, the wireless adapter specs, to the wireless? B, G, N, AC wireless?
Apr 13, 2013 | Computers & Internet
I have a Zyxel P660HW-T1 v2 and when trying to use laptop wirelessly, the internet connection keeps dropping. While connected to the router by ethernet cable, internet is fine. All was working fine until...
For that you need to change wireless channel type in router. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless->wireless channel type to 3 or 6 or 11 then save settings and restart router. . Let me know if you need further assistance. Thanks for using FixYa.
Jun 22, 2011 | Zyxel Prestige 660HW Wireless Router...
I was helping a friend who has Earthlink DSL (a ZyXel DSL modem) to get her Linksys WRT160N wireless router working with the Earthlink modem. No luck. Earthlink won't help unless you pay $7.95/mo with a...
Hello mcneel,
The router should use the ZyXEL P600 as it's DHPC Server. And review/update the ZyXEL WAN configuration as follows:
• Log on to the ZyXEL P600 browser configuration interface: 192.168.1.1
• Enter username/password: Default is username:admin - password:1234
• Click '+' by Network in the letf-hand panel
• Click WAN
• In the Internet Connection tab, select the following options:
Name - (Any Name)
Mode - (Routing)
Encapsulation - PPPoE
User Name - (ISP login username eg. MyName@isp.com)
Password - (ISP Login password)
Service Name - (Leave Blank)
Multiplexing - (LLC)
Virtual Circuit ID
VPI - (Leave Blank: Issued by ISP)
VCI - (Leave Blank: Issued by ISP)
IP Address
Obtain an IP Address Automatically - ([X] Check this option)
Static IP Address - (Not Selected)
IP AddressI - (Leave Blank)
Connection
Nailed-Up Connection - ([X] Check this option)
Connect on Demand Max Idle Timeout sec
• Click 'Apply' button
• Close the browser configuration interface page
Finally, this link to the EarthLink DSL FAQ Setup Installation and Configuration page might offer some useful suggestions:
http://www.dslreports.com/faq/earthlink/30_Setup_Installation_and_Configuration
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Zyxel Prestige 645M (AM408405) Bridge
Ethernet to router connectivity issue
The correct way to do the connection is by plugging the Desktop to one of the Ethernet ports and any wireless device over the wireless network.
Dec 01, 2009 | Zyxel P660HW-D1 Router
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Zyxel nbg334w router configuration
Hi
To configure the wireless router it is recommended the it is connected directly to router.
Please follow these steps to fix your issue
1. Reset the router using reset button on the back of the NBG334W router
2. Configure or change the laptop ehternet adaptor setting to "Obtain IP address automatically.
3 connect laptop and router using ethernet cable. check the ip address using ipconfig command in DOS prompt. If IP address is 0.0.0.0 or 169.X..X..X run command
ipconfig /release
ipconfig/ renew
best way restart the computer
4. if you still have issue in getting ip address double check ethernet cable and try reseting the router again.
5. Still problem persist install new firmware on the router. you can download router firmware from
http://www.zyxel.com/web/support_download_list.php?indexflag=20040906164737&ModelIndexflags=0,420070320142921
Please vote if this information is helpful in resolving your issue
Dec 27, 2008 | Zyxel Prestige 334 Router
Configuring nbg334w router
ipconfig /release
ipconfig/ renew
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Zyxel Prestige 841 (91-004-226010) Modem Logo
478 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
