Welcome to Fixya. The error that you received from the computer was common to a usb device that is bad. The computer recognize that there is a usb device connected to it but it does not recognize it. You can try to connect the iPAQ to a different computer and if you have the same error the device is bad.
Thanks
Hi.there might be a damaged on your usb itself or usb port because it will not be recognized and read by the driver.
Unfortunately it seems you USB drive has had a critical failure. If it is less than 1 year old, you can contact the manufacturer for a replacement. USB drives, like any other drive, should always be backed up. If you would be lost or dismayed by loosing the information, back it up somewhere and maybe even two or three somewheres.
No. Everithing else works just fine, and I´ve replaced conection cable
Tried tahat also, but with same result. I´m puzzled with the fact that device works normaly, I can charge it via USB port, but not synchronize it. Could I damage something while cleaning the dust and, most importantly, what can I do to fix it?
