Question about Philips Televison & Video
Dtr 1500 flashing red light about ten times, then both come on for a while then flashing again, rset to virgin does not work and timer 0 does not work and holding the power for 15 seconds does not work - any clue
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
SOURCE: Panasonic PT-51HX43G no power, red light flashes
I have a Panasonic PT53TW53G projection tv that had the same problem for power .A terrific person gave us wonderful advice and it fixed our tv! We were told to replace the IC conversion amplifiers. On our model they are STK392-110 (your's may be different). We ordered the parts from www.electronix.com and they were only $12. for the two parts. We also had to purchase a soldering iron and de-soldering vac for removal/replacement of parts. Good Luck!
Posted on Feb 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: Sony Kp-fw46m31
count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
Posted on Apr 06, 2008
  • 3 Answers
SOURCE: stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Posted on Jun 06, 2009
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Could you please advise how to reset lamp timer on a fujitsu LPF 4800 when I turn it on the green light goes to red and the lamp light indicator goes to red too and blinks
hi
You can reset the lamb timer as follows.
While pressing the MODE button, press the POWER button three times.
all the monitors flashes for a few second , The lamp timer is initialized to[ 0 hours] .
ok
Dec 15, 2010 | Fujitsu LPF 4800 Multimedia Projector
When turning power on it goes right off led light on front flashes ten times then pauses then flashes ten times again mod# kdp-57ws655 ser# 9709614
It needs repair, Flashing of red light indicates faulty on the circuitry. Power supply or high voltage is faulty. Common cause is a defective PWM IC. MCZ3001d on power supply or high voltage section. Replace those parts and its done...
Nov 13, 2010 | Sony Televison & Video
Dtr dont work, low beams dont work. highs work if i flash switch.replaced bulbs, dtr relay, fuses, speedo cluster. unsure where ground is.
ok this is a easy fix...take out your drivers head light lens..under that is a bunch of wires..i think it is pink or red wire chevy had a prob with ...might be hard to find but 100% this is the prob there will be a broken wire there..like i said im sure it was pink or red....
Mar 04, 2010 | 1996 Chevrolet Cavalier
Retuning Philips DTR 1500 digibox
Had same problem. Remedy is to put digibox back to factory reset. Dis-connect from mains. Keep pressing + button on front panel as you re-connect to mains. Red LED will be on, when orange LED blinks release + button. briefly press + button. You have solid red LED and blinking red LED. Enter code 9 9 0 0, by remote blinking LED will show green. Wait a few minutes and the instalation page will appear on screen. Go to update and start as you did before and C5 should be installed. Hope that helps.
Dave
Sep 30, 2009 | Philips Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
My thomson dtr
just found this solution and it worked for me ............. though it wiped the hard drive ............ basically restores to factory settings
turn all power off and back on again press stand by button repeatedly until flashing amber light is n constant them quickly press up down left right in that order as quick as you can .............
good luck
Nov 11, 2008 | Televison & Video
Need help
try to press the timer button repeatedly untill u see time 00 is desplayed may be u solve your problem if it is in sleep timer mode and if u managed to rset timer to 00 and the problem persist your tv has a high voltge problem it delay to charge the tube.
Sep 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
62 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
