Question about HP OfficeJet 7310 All-In-One InkJet Printer
Two-sided orientation of text
I can print on both sides of my paper, as always. But I am now getting the second page upside down so that I must turn the paper UP rather than to the left. How do I correct?
  • 1 more comment
  • Anonymous Sep 09, 2008
    Same problem here. Is this a Vista issue?
  • Anonymous Sep 29, 2008
    I have reinstalled software, and cannot resolve the problem. I just use the manually print on both sides. I have had many problems since I installed this printer on my new computer with Vista. :(
  • iamjayare Mar 23, 2009
    i have the same problem, but i have XP....i uninstalled the printer and drivers as per HPs suggestion...but still the same problem...then they suggest that i reinstall drivers for a HP 990c printer...and that seemed to work...
    this happened suddenly after having the printer for more than a year...but HP does not have any idea why this would happen on its own...
    check on HPs technical support for help with that...they have step-by-step instructions on how to install the other drivers...
    good luck.
    Problem Solver:
  • 9 Answers
There is a setting in Printer Preferences that will flip the 2nd page of a double sided printed page 180 degrees. That is probably the first thing you checked but just in case...
Posted on Oct 16, 2008
  • HP Master
  • 4,338 Answers
This sounds like a software setting. I would reinstall the drivers fro HP's website.
Posted on Sep 24, 2008
HP8620 prints second page upside down
Change your paper orientation on your print driver from Landscape to Portrait.
Jun 18, 2015 | HP Officejet Pro 8620 e-All-in-One...
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Hi how do you print double sided please
This printer does not have a duplex unit and cannot print double sided prints automatically.
The only way to print double sided is to print page 1 and the insert the page back into the printer tray with the page upside down and then print page 2. Repeat this for the other pages.
You need to do a test print first to work out which way to insert the page upside down in the printer paper tray so the printed text is aligned correctly on both sides of the page.
Nov 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My duplex printer prints the second page(inside) of a half- fold card upside down. The printer wizard from orintmaster and printshop is designed for single- pass printers si that doesn't work... In fact,...
actually the gears in the printer are got worn out or some thing is blocking the gears so its not able to turn the paper internally to print on the right part of paper.and its printing upside down.remove the cartridge from the printer.and apply air blower in the inner area of printer.remove all the dust collected in the printer by blowing air everywhere in the printer.then check out if still the same problem the paper sliding gears needs to be replaced.you can get the gear assembly for local printer repair shop.they also help if replacing the gear assembly.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya
Oct 02, 2009 | Brother HL 5250DN Laser Printer
Booklet printing word on ir5000
WHEN YOU GO TO THEPRINT PREFERENCES CHECK THE ORIENTATION OF THE DUPLEX IT WILL HAVE LONG END BIND OR SHORT MAKE SURE IT IS SET FOR LONG END THIS SHOULD MAKE THE ORIENTATION RIGHT OTHERWISE IT WILL TRY TO PRINT AS A CALENDER WILL COME OUT IE LIFT UP THE PAGE TO SEE THE NEXT IMAGE
Jul 03, 2009 | Canon imageRUNNER 5000 Copier
MP610 How do I duplex print. I have had every second page print upside down. o I manually turn the page over/
I had the same problem, the operative being had!
All I did was change the paper orientation from landscape to portrait and the problem went away!
Hope this helps!
Robbie
Jul 17, 2008 | Canon MP610 Photo All-In-One Printer
Double sided printing
There should be a setting in the 2-sided properties for binding orientation.
For a MAC, do this:
On the File menu, click Print.
Open the Two-Sided Printing panel.
Select the option to print on both sides.
Select the binding orientation by clicking the appropriate icon.
Change any other settings, and then click Print.
Feb 26, 2008 | Computers & Internet
Duplex printing
I think you given the wrong printing on one side. So Check the page orientation and do the printing
Sep 29, 2007 | Canon PIXMA iP5000 InkJet Photo Printer
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
How do I print on both sides of my paper
On printers without a duplexer (a device that flips the paper to allow printing on both sides) you will have to print the first side, manually flip and print the second side. If you're using MS Word or MS Publisher you can easily configure the program to organize the pages for you: Start a new, blank document. -Click File, Page Setup then click the Margins tab. -In the Multiple pages section select Book fold. -Set your document to landscape orientation if it is not already. -In the Inside and Outside boxes, type or select the amount of space you want for your margins. -In the Sheets per booklet list select the number of pages you want to include in a single booklet. If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets. -When you get ready to print make sure you check the manual duplex box (should be in the first dialog box that appears when you click on File, Print). Word will print the first page, and then prompt you to take the pages that just printed and load them into the input tray of your printer. The trick is to learn how to orient the pages correctly for your printer. Good luck.
Jun 17, 2007 | HP DeskJet 1600C InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
