Question about Wharfedale Televison & Video
Need an AV lead for 9'' portable dvd player (dvd-265)but no part number in instruction manual
  • Anonymous Mar 14, 2014
    Just need the parts.
  • Wharfedale Master
  • 2,794 Answers
I'm only finding information on E-Bay and Google that indicates there is a 2 channel audio output but nothing listed for video output. What kind of connectors does the DVD player have on it? Are they mini jacks or RCA?
Posted on Aug 31, 2008
Can I connect my to iPod Classic to watch video on Sony DVP-FX970 Portable DVD player? If so, what connection do I need?
The DVP-FX970 uses a composite (3xRCA) to mini-AV (2x mini-plugs) reducing cable. This is Sony part 9-885-103-56 and was included with the DVD player in the original packaging. See https://sony.encompass.com/item/7054170/Sony/9-885-103-56/Av_Cable_(010-0001-206) . Other vendors may also have the cable. You will also need an RCA (3xF) coupler, see http://www.cablestogo.com/product/40647/composite-video-stereo-audio-f-f-coupler-taa-compliant for one option. Connect the composite end of the above cable to one side of the coupler and the other side to the DVD player. Next connect the appropriate iPod Classic video dock, https://www.apple.com/shop/product/MC748AM/A/apple-composite-av-cable , to the other side of the coupler and the iPod Classic. Now, turn on everything and press the Input Select button for the DVD player multiple times until the current input is 'Line In'.
I hope this helps.
Jun 24, 2017 | Televison & Video
Bush 8382i portable dvd player wont fit the av leads to connect to the TV
AV lead sockets pins are of standard types. It has an international standard. See it.
Jun 05, 2012 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
My sony portable dvd player stopped working. The
If the DVD is connected to the TV properly using the yellow, white & red AV cable and the TV is switched to AV and there is still no picture, plug the yellow lead from the back of the DVD player into the green socket. If you see a black and white picture now the DVD output is on Progressive Scan mode. See user manual to turn off Progressive Scan mode.
Aug 31, 2009 | Sony DVP-FX810 Portable DVD Player
How do you connect the portable dvd player to your big screen tv?
Look on the side of the dvd player you should see a connector that says AV Out or Video Out, you will need a wire that plugs into that which depeding on the model of dvd player can be either the Red / White/ Yellow Phono Plug Leads or a Lead which has the Red / White/ Yellow Phono Plugs and at the other end what appears to be a headphone jack connector with 3 black bands on it indicating that its a 4 Pole Video output cable, then you plug the Phono Plugs into the Phono Sockets on your tv, using your Tv remote you will need to select which input you got the dvd player plugged into this will either be called
Source Or Input Or AV 1-2-3 ect.
jon
Aug 11, 2009 | Initial Televison & Video
How does my mum reinstall this dvd on a new tv she has lost her instruction manual and i am attempting to help her over the phone!
Advd player does not need tuning , simpley connect red white and yellow RCA leads from the back of your DVD to AV... input of tour TV use TV remote to select the same AV source eg AV1 AV2
Apr 21, 2009 | Yahoo YDP305 DVD Player
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
Televison & Video Logo
82 people viewed this question
Top Wharfedale Televison & Video Experts
Colin Stickland
Colin Stickland
Are you a Wharfedale Televison and Video Expert? Answer questions, earn points and help others
