Question about Microwave Ovens
Hotpoint microwave oven JES636
Brand new worked two times, now the start will not start no matter how much i clear it and unplug it. All the other buttons register, but when start is pushed it wont start.
  • Anonymous Sep 12, 2008
    i have the same problem. i used it maybe four times and it worked fine. then next time i went to use it however, it would not start. all the buttons are functioning but it when i press start nothing happens.
  • Microwave Ovens Master
  • 9,086 Answers
Sinceit's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here and they can help you find a local servicer.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Posted on Sep 01, 2008
Microwave turns on but keypad doesn't respond.
If it's brand new it should easily be returned to the manufacturer (Or retail outlet) So dont worry, Just take it back tell them your problem,. They'll probably be happy to help, This is a situation where you can do little if anything and are probably facing a defective product
Dec 02, 2013 | Bosch 800 HMB80 1000 Watts Microwave Oven
Hotpoint microwave only works a few seconds then shows all 8s in the display
Sounds like its time for a new microwave
You can probably buy a new one cheaper then fixing the old one
Most controls that display 888 something is shorted out on the controller.
Have you tried unplugging it for 5 minutes and plugging back in?
Aug 24, 2013 | Hotpoint RVM1435 Microwave Oven
I have a new hotpoint microwave and it completely shuts off after 3 minutes and in a minute or 3 later it turns back on
First if it is brand new it has a warranty---call Hotpoint customer service or even take it back where purchased for exchange or repair.
Oct 21, 2012 | Hotpoint Hot Point RVM1535DMCC Over the...
Microwave does not work at all. Shows "PF" in display.
"PF" on the display is an indication that your oven experienced a power interruption. Normally, the error code can be cleared by pressing the CLEAR/OFF button. You may have to reset the time. This is accomplished by pressing the CLOCK button, entering the time on the keypad, then pressing CLOCK again. If this does not clear your problem, please let me know. I hope this helps you.
Jul 26, 2011 | Hotpoint RVM1435 Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Hotpoint Microwave - won't stop spinning/buttons seem to do nothi
if i understand, u say it is intermittent right? control pad get wet? it is definitely not mag, diode, cap.
Aug 19, 2009 | GE Microwave Ovens
Brand new Hotpoint Microwave doesn't heat
Brought microwave back to store. It didn't appear to be something I would be capable of fixing myself.
Got a new one which is working fine.
Mar 21, 2009 | Hotpoint RVM1535MMSA Microwave Oven
My ge profile microwave oven sometimes turns on when door is clos
hi and wellcome to FixYa this is a comon problem with the control unit for the microwave being damaged the buttons start to stop working more or few buttons at a time, there are companys that sell the front units seperate for these microwaves but can cost more than a new microwave itself , the unit itself is damaged by heat from the microwave or on rare accasions damp im sorry there is no other way to sort this apart from a new front control unit or a new microwave
Thanks Hope this helps a little
Feb 06, 2009 | Whirlpool MH7140XF Microwave Oven
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
Microwave Ovens Logo
71 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
