Question about Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven
Maytag Microwave Hi, I have an over-the-range microwave. The fan will not turn off. I let it run for several hours and then had to unplug it. Every time I plug it in to use, the fan will run and then I simply unplug it again. It seems to be cooking just fine. When I choose a low setting for the fan it will run hi and when i choose the hi setting it sounds low. It doesn't matter what the setting it will not go off. any advice? thank you, thank you!!!
  • Maytag Master
  • 9,098 Answers
Chances are you have a stuck relay on the control board.
We regularly repair these for customers nationwide with our guaranteed $39.95 service.
It's also possible that your model may have a hood fan thermostat, and it may be stuck closed.
We would need your model number to see if it has one.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
I would invite you to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 01, 2008
How can I get the fan to turn off when the microwave is turned off?
Most GE over the range microwave ovens have a cavity heat thermostat. if the exhaust fan cut on due to external heat generated to oven, the fan will run until unit totally cools down. in this case unplug unit. Also fan can run if you have a broken door paw or if one of the door secondary switches is bad.
Aug 09, 2014 | GE SpaceMaker Microwave Ovens
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
Maytag over range rattling and vibrating noise
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
Mar 15, 2014 | Maytag Appliances Over-the-Range Microwave...
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Maytag mmv4205bab continues to run after time is up. The fan does not circulate, but it continues to heat.
Our microwave in office won't shut off. It continues to heat and fan is running as soon as we close the door. Tried everything, unplugged, canceled everything. Please let me know what to do.
Oct 04, 2010 | Maytag MMV4205 Microwave Oven
MMV5100AAB Over the Range 1500 watts 3amps -turntable does not turn -does not heat -light works- unit makes loud running noise but will not turn off -must open door or unplug to turn it off. Never any...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 10, 2010 | Maytag Microwave Ovens
Exhaust fan is running constantly, without even
It could be that the fan button is sticking or a contact has welded itself closed therefore its getting power all the time.
Mar 08, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag MMV5165 Stainless Steel 1000 Watts Microwave Oven Logo
95 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
