Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1998 Fatboy Bike will start and run - maybe a mile or 100 miles then it will quit for no reason - like when you turn the switch off - last time it did not start back up had it picked up next day it started right up,
Yup- had the same on my custom, thought it was carb drying up. turned out to be coil wasn't mached ohm-wise to ignition. coil change solved it for last 3 yrs!
Posted on Sep 02, 2008
Sounds like the coil
Posted on Sep 01, 2008
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
May 24, 2014 | 2004 Honda VT 750 Shadow Aero
Car dies for no reason
i would check the fuel pump for proper pressure
Apr 19, 2014 | 1998 Honda CR-V
I have a 1991 Honda ST1100 with about 48K miles. The starter will not turn over. It quit one day after a 100 mile ride in hot weather and would not start a couple of hours later. The battery checks out...
what exactly does "the battery checks out good" mean? What is the voltage reading that you are getting? If anything lower than 12.7 V then that battery is shot or on its way out.
The solenoid not clicking could mean 1 of 2 things.
1. Not enough juice going to it to activate it.
2. The solenoid itself is bad.
If you short out the solenoid by touching both terminals with a screw driver, does the starter start then?
Apr 18, 2017 | 1991 Honda ST 1100 Pan European
Valkarie 1999, runs fine some times more then 100 miles, then out of the blue starts missing like out of gas, it wont go, I turn off bike wait a few minutes and it runs fine.
fuel,fuel filter, vapor lock, vented gas tank not venting,bad gas caps, dirty screen,maybe at pedcock,sounds like a fuel problem to me!
Mar 12, 2011 | 1999 Honda F6 C Valkyrie
Where is the gas gage on 1998 valkyrie
There is no gas gauge. You have to set your trip mileage on the speedometer to 0 each time you fill up the gas hog. I go 80 miles before I have to switch the tank to reserve leaving maybe 20 miles left before walking. Don't even think about pushing that bike to the gas station just leave it. You will need a good insurance policy to protect against theft if you leave it unattended.
Feb 13, 2011 | 1998 Honda F6 C Valkyrie
2001 nomad, has power commander, vance and hinse exhaust and hyper charger. Bike starts but miss fires. Bike seems to run better uphill then down hill. It started on day on a ride when the bike just died...
DRAIN CARBS FROM PETCOCK AT BOTTOM OF EACH CARB MAKE SURE FUEL DRAINS COMPLETELY THEN TURN FUEL BACK ON, IF THIS IS AN INJECTED MODEL DRAIN TANK AND FLUSH THEN RUN IT HARD FOR 20 MILES OR SO, MAKE SURE YOUR OIL LEVEL IS OK
Oct 04, 2009 | 2001 kawasaki VN 1500 Vulcan Classic...
I have a 97 Fatboy that sometimes loses spark
test or replace your ignition module,and you might find the actual prob by accident the connector for the module sometimes with age lose or only have intermittant contact.a can of electrical contact cleaner should take care of it but those symptoms scream ignition mod dont know why hd dealer couldnt find it but they dont put their best techs on older bikes
Jul 15, 2009 | Harley Davidson Harley-Davidson Motorcycle...
I have a 99 Mazda 626 that just quits running when you are driving down the road. Today it quit and I waited about 20 minutes and it started right up. Anyone know what could be causing this?
Try replacing the ignition switch underneath the steering collar. Pop of the top then the bottom you need a screw driver or ratchet cant remember. Its very easy to replace. I suggest buying a repair manual to see what it looks like. Very small part smaller then your hand. The part cost 100 or less with life time warranty. DO NOT BUY IT FROM THE MAZDA DEALER. They warranty their part for only 9 months? Or 30k miles.
If it starts to putter or not stay on and turn off like you describe it maybe the switch. When you install it first it may shudder or have a high rpm. I think it does this because the main computer is trying to adjust. You may have to turn it off 5 or six times or drive around the block a few times to get it to adjust. I have replaced mine twice already since I have hit 234,000k miles on it. It does burn out and my car at times will not start or turn and try to turn of while I’m driving and stop at a light with low rpms.
Jun 24, 2009 | 1999 Mazda 626
99 HD softail stalling problem
If this is occuring everytime you ride the bike and always when it gets warm. I would think there is a good chance that the sensor in the timing cover is getting hot and then developing a short. You can replicate this synario by taking a hair dryer and warming the cam cover around the timing plate, if the bike wont start after warming the timing cover then you have a bad ignition sensor plate. if the bike still starts you can also try the same technique with the ignition module itsself which should on that model be located behind the battery. heat causes shorts in those 2 items quite often. try it out and let me know what happened.
Mar 31, 2009 | Harley Davidson FXSTS Springer Softail...
Lands Phones Logo
286 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
