Question about Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard
No boot after removeing the battery and the c-mos battery for 1/2 hr to clear bios password the system will not boot again i dont what do to do
  • 797 Answers
Hi:
You need the manual.
You also need to know what bios you have.
Take the battery out for 24 hours.
Most motherboards I have worked on will not discharge in only a half hour. You need a lot more time than that.
You can also clear the cmos on the jumpers. Be sure you know which jumpers, otherwise you may damage the board.
By shorting two of three jumpers, the cmos will be cleared to factory settings.
thanks,
Posted on Sep 03, 2008
Got a dell latitude e6400series forgot bios password can i fix this problem ?
Welcome to Fixya
Common procedure in resetting the password is by resetting the motherboard by reseating the CMOS battery. You need to access you motherbard and locate the circular silver metallic object on the motherboard. This is much bigger in size compared to a wristwatch battery. CAREFULLY remove the CMOS battery, avoid touching it with your fingers, and leave it out for about 120 seconds. This will flush the CMOS memory which stores the BIOS password and all other configuration. Put the the battery back in and turn on the computer.
Other procedure is the jumper reset. Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
If procedures above has been done and yet you are getting same results. Its time to call you manufacturer and have the motherboard re-flushed or re-imaged.
Thank you for using Fixya!
Mar 31, 2011 | Computers & Internet
I need a password to put it back to factory
I Hope you are asking the bios password. I f so then remove the c-mos battery then start the system. Once the display comes, switch it off then put the battery again, then start the system. After which go to the bios setup & do what ever you want. this is called bios refresh.
Jan 17, 2011 | Computers & Internet
I have problem with the lock paswerd
If you have a BIOS level Password (Before Windows) contact Dell Tech support (800-624-9896 USA) confirm ownership and they can assist in clearing the password.
If it is a Windows Password, you will most likely have to either remember the password, boot to admin account in Safe mode (If XP Home) and change the password there, or reinstall windows
Aug 07, 2009 | Dell XPS M1210 Notebook
BIOS password
Its in the motherboard.... remove the c-mos battery and then place it again...it will reset the bios password..
Jun 12, 2009 | Panasonic Toughbook 50 Notebook
Acer Travel mate 517TE C MOS low battery warning msf at Power up
If you clear the cmos you are just loading the defalt bios settings but not solving the problem.
In this case you dont have to clear the cmos but instead replace the cmos battery.
Dec 12, 2008 | Acer TravelMate 517TE Notebook
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
BIOS PASSWORD
There is only one to remove that is to:
If you know how to open the laptop then follow this but, if you don't then plz do not do this. BE WARNED.
1 OPEN THE BACK
2 REMOVER LITHUIM BATTRY
3 WAIT ABOUT 15 MIN
BY WAITING YOU R CLEARING YOUR BIOS
4 NOW INSERT YOUR BATTARY
5 CLOSE COVER
6 PLUG IT IN
7 BOOT
NO MORE PASSWORD
Jul 29, 2008 | Sony VAIO VGN-S460 Notebook
No boot
Turn system off / Than try to re-boot after it comes back on.
If this dont work retry again with the battery back in , than turn system off and see if it re-boot again if so , take battery out and re try again with the normal re-booting .
Nov 29, 2007 | Compaq NX6110 TFT XGA Notebook
PASSWORD PROBLEMS
Hi, To access or enter motherboard BIOS settings, on powerup either F2 or Del. If you just want to remove the password in your Dell Optiplex > The BIOS password may be cleared by removing the password jumper (PSWD) on the motherboard. This will also clear all CMOS settings: Open your casing, on your motherboard. find the CMOS password reset jumper (3-pin) on the motherboard; Remove the jumper from pins 1 and 2 and put it on pins 2 and 3 for about 5 seconds. Replace back the jumper on pins 1 and 2. Hope this be of help/idea. Good luck and kind regards.
Aug 27, 2007 | Dell OptiPlex GX270 PC Desktop
Compaq Presario 1200,1600, Series CD ROM(297657-001) (EP8RDA3G) Motherboard Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
