Question about Kenmore 73952 Gas Dryer
Kenmore 90 lp conversion
I need to convert to lp. how do i access the burner ?
  • 55 Answers
  1. I think the jet will have to be replaced--I recommend you go to a Sears store with the manual of the unit and request help. I you do not have the manual record the data from the data plate and bring to the store. The burner is probery underneath the unit. Access would be either the rear or underneath. Try calling also. JOHN -LA.
Posted on Sep 01, 2008
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
Kenmore grill 146.23766310
Here is the owner's manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1212186L.pdf
In it, it states, "Use grill, as purchased, only with LP (propane) gas and the regulator/valve assembly supplied"
Oct 30, 2013 | Grilling
I just purchased a GE frontload W/D set from a local chain retailer who didnt offer installation on the gas dryer that required conversion
Behind the knob on the control panel is a screw that needs to be removed to remove the control panel. Once removed, there is 4 screw around the door frame and two screw on the top of the front panel that needs to be removed to access the burner you seek. Converting to LP
Although this link if for a Whirlpool dryer, the burners and premise is the same. I hope this helps you, good luck.
Oct 10, 2013 | Dryers
I DO NOT HAVE NATURAL GAS AVAILAABLE WHERE I LIVE/
You can order an LP conversion kit to change it over to propane. Most kits cost between 30 and 60 dollars, and require you to take the drum out of the dryer to access the gas valve for the change over.
May 07, 2010 | Kenmore 73952 Gas Dryer
Do you have instructions on how to convert a deep fryer to LP I have a Pitco 35cs I need to convert to LP
Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts dealer on your area and ask for the conversion kit (from nat to lp). The gas valve conversion kit consists of spring, cap and instruction manual. you also need to replace the burner and pilot orifice, Nat pilot and burner orifice have larger bore than lp.
Apr 06, 2010 | Pitco Frialator 35CS Deep Fryer
Need to convert from lp to ng on a kenmore 362.7556191
conversion should be done by a qualified tech. you need ng orifices to replace the top lp orifices on top burners, you need to turn top of regulator over to ng, this is located behind bottom door and you need to adjust your orifices in your oven burner back up, should be screwed complerely down now and same for broiler also air adjustment may be needed. do not recommend you try this yourself
Feb 05, 2010 | Kitchen Ranges
Accessing burner and installing LP conversion on Maytag Bravo
you need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
May 19, 2009 | Maytag Dryers
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
KitchenAid 5 burner Cooktop conversion to LP gas
you need orifices for lp and the regulator should be convertable there is a "plug" thing in the middle of it that you remove and turn over and install
Apr 15, 2008 | Cooktops
Kenmore 73952 Gas Dryer Logo
83 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
