Question about Sony Cyber-Shot DSC-F717 Digital Camera
Has my F717 kicked the bucket?
I last used my 717 last weekend w/no problems, and after charging the battery last night, tried to take some photos today. When I cut the camera on and removed the lens cap, everything on the LCD was "smeared". I switched to viewfinder with the same results. images I saved to the memory stick last week are clear when viewed, but I can't for the life of me figure out what is happening now.
    Master:
  • 551 Answers
If the LCD is "smeared" in record mode, it isn't the memory stick or any of the other solutions you've been offered. It's one of the following, I would guess: 1) condensation in the camera 2) loose or bad connector to the CCD or power supply 3) Camera is history. Hit eBay and get a new one BTW, It costs about $175 for repair by Sony (at least the last time I had a repair done on a 717). It's probably worth it as long as the rest of the camera is in good shape. Definitely cheaper than buying a new one or a used one. Sorry about your problem...
Posted on Sep 12, 2005
Sony has a problem which they are adressing free till Oct 2 2007. They have a quick diagnostic procedure which will let you know if this failure is completely covered shipping and all. http://esupport.sony.com/perl/news-item.pl?mdl=DSCF717&news_id=118
Posted on Aug 19, 2007
    Master:
  • 551 Answers
Had a similar problem which turned out to be the card reader. Direct USB from the camera works fine.
    Master:
  • 551 Answers
Did you try a different memory stick? it's the only thing i can think of testing. (right now)
Coolplix S210 can't take photo in flash mode
The flash is trying to charge. Try a freshly charged battery in the camera. If that doesn't work, go into the options menu and set them to factory default. Try the camera again. If that doesn't fix it, there is a defect in the camera.
Mar 30, 2010 | Nikon Coolpix S210 Digital Camera
Phone won't charge or turn on
Try removing the battery and clean the contact's, then reinsert the battery and let it charge, if it do'es not begin to charge your adapter may need to be replaced, or your battery.
Apr 06, 2009 | Lands Phones
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Sony cybershot f717 battery won't charge
Same for me too... And a bunch of other stuff! I can't choose to have the flash, can't use the veiwfinder...
Oct 11, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Battery fully charged but my Sony F717 just unable to switch on.
Problem is occour in camera power supply section. There are 4 fuse in BT-015 Board if they are okay than check FR-194 Board. on this board IC001 DC control is faulty. I hope problem will be solved
Oct 09, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
DSC-F717 won't turn on
You are correct. The battery has lost it`s life.
Contact your nearest Sony dealer and ask them for the NP-F50 battery which I think your camera uses.
The reason why the battery still shows it is charging ( if your interested ) is due to the sensing cct - you will see your battery has three poles and not just 2. The sensing pin is faulty due to the buildt in PCB having a problem. The batteries probably are still ok inside, but the sensing cct does the actual charge control.
Best of luck.
Mar 05, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Memory stick error
This is a problem with the battery connector inside the camera. It is common to the DSC F717 and this camera. It's, unfortunately, a pro camera repair issue on the 828. It can be fixed DIY on the 717. I did it to mine and now it works fine.
Dec 13, 2007 | Sony Cyber-Shot DSC-F828 Digital Camera
Overexposed still pictures?
This is a defective CCD problem known to Sony. They'll pay for shipping and repair it free of charge. Go here for details: http://www.imaging-resource.com/badccds.html
Nov 25, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Reddish vertical lines on LCD & view finder
There is a CCD service advisory for the F717. They will repair it free of charge. Go here for more details: http://www.imaging-resource.com/badccds.html
Sep 06, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Quality Problem
I had a Sony F707 for quite a number of photos before buying an F717. I found the F717 to underexpose by about 0.3EV relative to the F707, pretty consistently, so I just set the EV compensation on the F717 to +0.3EV most of the time. The F717's color balances tend to be neutral to cool compared to the F707's very (generally overly) warm, bright colors. This is a plus: you can easily snap them up in post processing where the F707's results sometimes clipped a lot due to the oversaturation. Of course, you have to make additional adjustments based on what kind of light values and contrast range the scene you're shooting has ...
Sep 13, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
71 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
